Question about Amana Heating & Cooling
My Amana ptac has an error code FO what does this mean?
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 706 Answers
SOURCE: GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Posted on Sep 22, 2008
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
SOURCE: How do you override the FD in the Display of the Amana PTAC
I just had that problem of having fd display and it locks everything up. makes sure you check the ds1 and ds2 and ms1 and ms2 if these are shorted then you will get that problem. I had to wiggle the wires in the connector and it worked as soon as i pushed on the right wire. They apparently are very sensitive.
Posted on Nov 11, 2009
  • 614 Answers
Goodman Industries has purchased Amana. So go to Goodman website for info.
Posted on Dec 17, 2009
Amana Ptac 2012 R410A runs compressor 5-10 min then will not run only fan. Freon level is good. Reset and compressor will run again then only fan again..cleaned
You said in another post that the error was c7. That means evaporator freeze. Too cold. That could be lack of air flow, bad sensor, ice on the coils.
Sep 11, 2016 | Amana Heating & Cooling
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
Where can I find a troubleshooting manual for the DS01E amana t-sta?
Feb 19, 2015 | Amana DS01E - DigiStat Thermostat with...
What does PF code mean on Amana PTAC unit?
I would assume that there was a recent Power Failure (PF) or that it may still have a power failure. Find the double pole breaker and turn it off and back on
Dec 05, 2013 | GE Zoneline AZ38H12DAD Split System Air...
My amana ptac is not heating....the code "np" is do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Heating & Cooling Logo
76 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
