Hi There I opened front control panel of dishlex dish washer 560 silent series. detached plugs from circuit board, didnt mark, not sure how connetc which plug to which terminal any help possible?
  • Washing Mach... Master
  • 5,323 Answers
Some connections may be color cordinated, and if u have the schematic it should help u locate where they go, next time always take pics of board b4 disconnecting
Posted on Jan 14, 2017
F 01 fault code on front load washer
ERROR CODE F01
The pump driver fails to activate/One of the main relays is not working properly/
A communication error between the Central Control Unit (CCU) and the EEPROM
onboard the CCU occurred.
Check for loose power outlet. A loose power plug in the wall can create
line noise and issues.
- Check if washer is on a dedicated circuit. Other devices on same circuit
can create line noise and cause this issue.
- Unplug washer or disconnect power.
- Make sure that wire harness connections from the CCU are not broken or with wires
detached, and that connector internal pins are visible.
- Make sure all green wires (ground harness system) are not broken or detached.
- Make sure the two ground switches are pressed correctly by the toe and rear panels.
- Make sure all connectors are fully seated.
- Plug in washer or reconnect power.
- Check for power going to Central Control Unit (CCU) by listening for a click in the
CCU when unit is plugged in washer or when reconnecting power.
- Verify unit operation by performing the Diagnostic Test.
- After the diagnostic test has finished, unplug washer or disconnect power
and wait for 15 seconds.
The CCU is located under the top panel which you already removed. Here is the part to order.
Nov 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Dish washer will not turn on or start! It is plugged in and connected to water
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Maytag Dishwasher
Water wont heat on my dx 308 stailess dishlex. its ellectronic. is there a reset or does the heater ellement need replacing? cheers
Unplug your dishwasher,then remove the front upper control panel.You will see a series of plugs.Note where they all come from and carefully disconnect.On the circuit board you might find a track melted off.Solder a small wire across the 2 joints.See how that goes.
Dec 27, 2010 | Dishwashers
KitchenAid dish washer: Control Panel Problem
Circuit board/ Electronic control assembly needs to be replaced.
Jul 24, 2009 | Dishwashers
I have a electrolux dishlex dx302 that will not heat the water and dry ,how dose it work?
Yes I had the same problem. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Jun 29, 2009 | Electrolux Dishwashers
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Replace Control panel cover on dishlex dishwasher 500E
If your 500E is the same as my 500E then the controls are electronic touch buttons. The are part of a self adhesive strip and stuck to the front of the door. No screws involved. Only the LED lights are mounted on a circuit board with screws on the back of the plastic front panel. ?????
May 09, 2009 | Dishwashers
Electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
May 07, 2009 | Zanussi 24 in. DE6850 Free-standing...
Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Dishwashers
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
