Televison & Video Logo
Taylor Osburn Posted on Dec 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv goes to the sharp logo when I turn it on and it freezes on the logo
Electro Med Services
Level 3:
  • Sharp Master 6,694 Answers
  • Posted on Dec 29, 2016
Sharp Master
Level 3:
Answers
6694
Questions
Helped
1870106
Points
21433
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here....
Sharp LC-50N7000U logo comes on then black screen, what needs replaced?
Best bet would be main board, sounds like firmware in EEProm is corrupt
What part of my TV is broken?
sounds like power board bad and could have bad control board also
My sharp tv powers on and shows the sharp logo then screen goes black
Unless you can do it yourself taking a TV to a service shop may cost more than its worth to have backlights replaced...Ive never had one cost 300 but its typical to spend $150 if its a larger set, I charge $2 an inch for the labor plus the cost of parts.
Sharp lcd tv turning on, sharp logo comes up then it powers off
can be backlight issue. lamp defective in lcd screen. try to force on unplug tv .and then press and hold volume - channel+ and input buttons on tv while holding down these buttons then plug in in. will come on .its mean lamp defective.
1helpful
Sharp AQOUS 42 tv will not turn off and displays the Sharp logo and the screen goes black, like it is transitioning, but never transitions to another screen. How do I fix this and what is the issue?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
When turned on, why does it just display SHARP logo?
The logo displays when you turn the tv on. You need to select a signal from one of the inputs. Pressing the input button repeatedly will cycle through the inputs. As long as one or more of them is on and broadcasting you will find a picture.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
