Question about Hamilton Beach Blenders
I need a clutch for a Hamilton beach blender model #52655. The black piece on the top of the base that spins the blade.
5 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
espressonist
  • 1711 Answers
SOURCE: how to change clutch in Hamilton Beach blenders
You need a screwdriver and soft hummer. Secure the screwdriver on one teeth of the cluch and lower the screwdriver to have un angle of around 60 degrees. Now you hit a little fast the scredriver with the hummer in order to unlock and unscrew the clutch. Then it will be easy to unscrew with your fingers. This is a litle bit triky so you may need to try some times in order achieve it.
Please remeber that you it unscrew reverse than it rotates.
The new one need only to screw in place and it will lock by itself as soon as you will use the blender.
Good Luck
Posted on Aug 17, 2010
  • 1739 Answers
SOURCE: I have a hamilton beach blender mod.52655 i need
The Use and Care Guide for the Hamilton Beach 52654 Blender can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840164501.pdf
Should there is insufficient detail here on the parts, I would recommend you contact Hamilton Beach Customer Service directly: See here for contact information:
http://www.hamiltonbeach.ca/contactus_new.php
Posted on Jun 30, 2011
mc1bean
  • 3053 Answers
SOURCE: How do you remove the drive clutch from a Hamilton
Hello, jim
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Hamilton Beach Blender Gasket
Possibly the gasket while it lasts on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e For an unused replacement, try typing in your model number at HB's parts site, located by clicking here . Many www sites like abtecparts.com and goodmans.net could help you. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
Apr 09, 2014 | Hamilton Beach Blenders
I have had my Cuisinart SmartPower blender for about 10 years now and it has worked great. Recently there has been a black dust/stain/residue that is on the underside of the bottom collar/blade and on the...
At 10 years you are heading to replace it. With the blender bowl removed, try turning the connector the goes to the blades. Then do the same with the connector on the base. Whichever one doesn't turn easily is the one that is failing. Usually there is corrosion in the spindle of the jug and this causes tightness which in turn causes the connectors to shred. The tightness cause friction, which makes the plastic parts get hot. The blade should spin easily, the connector on the motor, not quite so easy. On some blenders you can switch the base on with out the jug being on it. Run it for 30 seconds and then switch off. If it stop dead, then problem is with the base and the spindle that goes to the motor. In a catering environment, I had a Hamilton Beach, shatter the base connector after 2 years. With blenders, you get what you pay for, Cuisinart aren't bad, but there are better makes if you use them a lot.
Aug 19, 2017 | Cuisinart SPB-7 SmartPower Work Top...
Can't seem to find proper gasket and blade assembly to fit Ham Beach Blender #50100 Type B-12. Any suggestions?
Possibly the new wave action blade cutter while it lasts on cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-WAVE-ACTION-CUTTER-BLADES-REPLACEMENT-PART-/161615007502?pt=LH_DefaultDomain_0&hash=item25a1014f0e. For unused replacements, try typing in your model number at HB's parts site, located by clicking here . Abtecparts.com may also have traditional blades at http://www.abtecparts.com/commerce/search/products/?product_id=02AXHBha010&merchant_id=1933. Besides matching description, I would match the pictures of what you are going for against what you've got--unless you are trying something new--as much as possible. Good luck!
Jun 19, 2013 | Hamilton Beach 50100 BlendMaster Work Top...
Need replacement top for 56205 HB
Possibly on the cheap at http://www.ebay.com/itm/VINTAGE-HAMILTON-BEACH-BLENDER-REPLACEMENT-GLASS-JAR-LID-with-FILLER-CAP-BLACK-/161614461759?pt=LH_DefaultDomain_0&hash=item25a0f8fb3f Try typing in your model number at HB's parts wesite located by clicking here . Check out the many www sites like abtecparts.com and goodmans.net. Besides matching description, I would match the pictures of what you are going for against what you've got as much as possible. Good luck!
Mar 12, 2013 | Hamilton Beach 56205 Smoothie Start 56205...
What material is the The Hamilton Beach Wave Crusher 8 Speed Blender 1 EA58142 made of?
The The Hamilton Beach Wave Crusher 8 Speed Blender 1 EA58142 is made of patented stainless steel Ice Sabre blades.
Feb 07, 2013 | Hamilton Beach Wave Crusher 8 Speed...
I have a hamilton beach blender mod.52655 i need the parts list
Jun 06, 2011 | Hamilton Beach BlenderChef 52654 12 Speed...
How to change clutch in Hamilton Beach blenders
Good Luck
Aug 02, 2010 | Hamilton Beach 908 Commercial Work Top...
The base is broken
check with abtec.com. They seem to have parts for the Hamilton Beach model 50754 blender but I seem to remember the blade and base come as one unit.
Nov 28, 2009 | Hamilton Beach 50754 WaveStation 10 Speed...
HB model 52735C type B35..intructions for blender pls
go to hamilton beach .com with model and serial no down load a book
Dec 31, 2007 | Blenders
Blenders Logo
121 people viewed this question
Top Hamilton Beach Blenders Experts
Henry  Thomas
Henry Thomas
John Tripp
John Tripp
eyecam
Are you a Hamilton Beach Blender Expert? Answer questions, earn points and help others
