Question about Refrigerators
Uline 15 wc stopped working.Replaced the thermostat and still no power to compressor . Used to give it a smack and it would run and cool but then stopped altogether .
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
bobicehouse
  • 1524 Answers
SOURCE: Freezer thawed. Replaced temperature control, replaced defrost timer, replaced defrost thermostat. Compressor relay is cycling. No cooling still. Help!
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
Posted on Apr 26, 2009
  • 286 Answers
SOURCE: uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Posted on Jul 15, 2009
  • 286 Answers
SOURCE: small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Posted on Oct 13, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: The Refrigerator compressor runs and the fans run
4355
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
Posted on Dec 24, 2010
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
U-line bar refrig/icemaker
The fact that the compressor is two years old does not mean it cannot break down again, give more details on the problem to troubleshoot further
May 27, 2008 | U-Line Refrigerator Ice Maker
I have a Duo Therm rooftop AC inb my 2004 General Coach park model trailer. It has a heat/cool thermostat with a slider for t-stat control and hi/low on/auto fan switches. On heat it works fine. ON cool...
Got to be a relay/ contactor that is bad. Tstat is not energizing the relay to bring the compressor on. If you can understand the schematics you need to find where your high voltage stops. If you give direct power to the compressor and it runs then obviously power is not going through relay. Either bad relay or that the relay is not being energized at all by the tstat with low voltage. Good Luck
Mar 11, 2017 | Heating & Cooling
I have a u-line icemaker in my boat and it will make a tray of ice but will not dispense it without manual intervention. Is there a par that needs to be replaced? Thanks for your help
Have you used the ULine cleaner recently needs to be run through the icemaker every so often (good water every 6 months bad water as needed)
Nov 14, 2010 | U-Line Icemaker
Small refrigerator stopped working 75r
Oct 09, 2009 | U-Line Uline Origins Series...
My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
Oct 07, 2009 | U-Line ?chelon 2175RB-00
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
Unit not working
could be a thermostat problem, check the thermostat for continuity. it should have, if not, then replace the thermostat.
tnx 4 using fixya,
drcool
Oct 01, 2008 | U-Line 75WC Wine Cooler
I gewt no power to my compressorcoleman 15 model
On these relays NO means Normally open when power is not supplied on the control voltage side. Most A/C system control voltage is supplied by a transformer, which supplies the thermostat, which in turn supplies the power to the relay when cooling is called for. If you do have, say 24 Volts present at the relay the normally open contact should close giving power to the compressor for cooling. If the NO contact is not closing you relay coil may be open. In this case replace the relay.
Apr 26, 2008 | Coleman Mach 15 Air Conditioner
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
