Question about Whirlpool Kitchen Ranges
F5E1 on the auto clean Whirlpool Range. Would it help to shut it off on the main breaker or is there some other way to fix this without a service ca call. I was quoted $300 to fix this
SOURCE: F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Posted on May 11, 2008
SOURCE: whirlpool range door locked
I have had a similar problem(locked after self clean and NO display.) After much research we found the solution through telephonic advice from a master appliance repairman. Mind you that I did NOT get any help from the Whirlpool Customer Service number. Customer Service said it was probably VERY costly to repair and probably a blown circuit board. We were convinced our 2.5 yr old oven was about to cost more to repair than it was potentially worth. Then our telephonic advice from a friend, the master appliance repairman came to our rescue. It was explained to us that whenever an oven in most ANY brand locks and remains locked, it is usually due to a blown out thermal overload protector. This is the thermostatic fuse that will burn out during a self clean cycle and it's designed to help protect your oven from overheating. It is a VERY quick fix but does require a replacement part. But rest assured if I can do this fix, you too can. I am a 46 yr old female nurse without ANY electronics experience and was coached through this by my brother. Here's what to do. Move your oven away from the wall and remove the back panel (simple screws holding it in place.) Unplug your range for safety reasons. If yours is gas (and mine is) be mindful of the gas feed (mine had plenty of slack and presented no problem but worthy of mentioning.) You are looking for a part that's sort of in the 10 oclock position, it's round about the size of a quarter and held in by 2 screws. There are two wires coming into it. My part has the actual part number written on it and was the very part number I was advised to find based off the model number. You can call any appliance parts house (mine is Fox Appliance Parts in Atlanta) and give them your model number of your oven. Ask them for the part number for a "thermal fuse." They will provide the number, ship it to you or if you're local, you can pick it up. It should be around $30. Here's the cool part...you can diagnose this FIRST to see if it will fix your problem by doing this one simple thing. Remove your actual fuse by unscrewing the two screws and then slide off the two wires attached (it will slip out.) Now take the two wires still on the back of your oven and patch the two contacts together. Now plug in your oven....relax...you are merely bypassing the fuse and it will not explode or anything crazy! If the thermal fuse is your problem, your oven display will now magically reappear and the door will unlock! Now you know definitively that this is indeed your problem. Replace the part and you're back in business. You MUST replace the part though as I've been explained that it is a key safety fuse to help prevent overheating, $30 fix, even a GIRL can do it, and it takes about 10 minutes. Try it....You most likely do NOT need a new oven and do NOT need a repairman. And I was ready to replace my 2.5 yr old oven! Totally not necessary and this is something you can do!
Posted on Feb 11, 2009
SOURCE: KGRA806PSS00
We had the same problem as well. everything locked up and the display board went dead. It turned out to be the thermostat in the back. Once that was replaced everything worked ok. . The serviceman told us to pull the oven out from the wall when self cleaning. It is because the heat disapation and air circulation from the oven is very poor when running at maximum temperatures and this burns out components. First check the termostat, which is a $20.00 item.
Posted on Feb 23, 2009
SOURCE: self clean cycle won't start...get message F5E1
F5E1 error means there is a problem with the door latch or relay.
Posted on Mar 14, 2010
SOURCE: I get an error code
What I did was hit cancel and hit the unlock button. Then I leaned against the door a bit as I hit the lock and hit the self clean and start the lock check dissapeared. I hit lock again and nothing else and it started the cleaning process.
Posted on Apr 13, 2010
Range throws an F5E1 code, cleaned the oven 2 weeks ago. Worked fine. Plugged it back in today to clean oven but it threw the code, door is not locked.this is in a rent house.
Using the 'self clean' function nearly always results in faults. We see it here all the time, burnt out elements, doors that won't open, fires and error codes. Google the manual for it. They are all online
make model manual
The error is listed in this link. Also look at the video tab
whirlpool f5e1 error code Google Search
Door latch problem
Whirlpool Super Capacity 465 E1 F5
Apr 09, 2018 | Ovens
I started the self-cleaning function of my Maytag oven, locked the door, and then got a F5E1 error message about an hour before the self-cleaning was completed, and I can't get the door open yet.
Is the cleaning cycle still going? If you have a separate circuit breaker in the load center of your house for the range, you could simply turn the range off, set the circuit breaker to off, and then try to open the oven door. When you turn the breaker back on, the oven should behave normally. Do this before attempting moving the range no matter if it is electric or gas - gas lines can break when you move a range, so be prepared to turn off the gas shut off on the supply pipe near the flexible line if it should break, then get a new gas line and install it before turning the gas back on. If you are the least bit unfamiliar or don't feel confident doing this, get someone who is either a professional or someone you know that knows how to address gas appliances to move your range. If your range is electric only, then you will have no worries once you cut off the power and reset the oven to off - then turn the power back on.
Nov 19, 2017 | Maytag Kitchen Ranges
F5e1 error what sure i do
the code indicates door latch not working. Try turning the power off at the breaker for 10 minutes then power it back up. If it return you should call for service
Dec 27, 2015 | Whirlpool RF378 Electric Kitchen Range
What is the solution if my oven beeps?
Hello friend, thank you for your inquiry!
I understand that your door is locked and you have error "F5E1" showing on your range. I would perform a reset on your appliance which can be done by flipping the household circuit breaker off for roughly ten minutes. If that does not correct the issue and you continue to receive the error "F5E1" I would contact a professional to come out and repair your appliance because it could be an issue within your UIB (user interface board) or main control panel. Hopefully this helps. -Matt
Sep 15, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool oven gas range is beeping and is displaying F5E1.
This is a problem with the door latch switch. You will need to remove, check for continuity with latch open no continuity closed should have continuity. If the switch has continuity with latch open replace. I have replaced quite a few of these over the years, they usually seem to go during a cleaning or right after the oven was cleaned. Enter your model # at www.appliancehelponline.com for an illustration. The switch is inexpensive and easy to replace.
Mar 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F5E1 error
>>Exception Note:<<
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
