Question about Kenmore Dryers
Can the filter of Kenmore Dryer 86573120 be replaced
    Top Expert:
  • Kenmore Master
  • 79,123 Answers
Go to www.searspartsdirect.com and check to see if the part is available.
Posted on Dec 29, 2016
Have a Whirlpool AWZ3413 tumble dryer that will only run for a few minutes before the filter light goes on and the heat stops. The filter isn't clogged, but if I scrape off the tiny amount of fluff...
Here are more possible routes:
Duet Dryer Moisture Sensor Bar part WP3387223 How To Replace (See the KENMORE note below)... You MAY want to try cleaning the Sensor with a Q-Tip and alcohol! Not too much though... just a dab.
more from the Internet...
"This is most likely due to the vent being clogged between the back of the dryer and where ever it exits the house! This accounts for the light and the long drying times. A dryer not only relies on heat but also air flow to dry. if air flow is restricted, drying times get much longer since the moist air can not exit the dryer."
whirlpool awz3413 filter light keeps coming on even though
Here is a VIDEO for a similar KENMORE (Whirlpool). IF you suspect the SENSOR is bad and HOW to replace it:
Whirlpool Kenmore Duet HE3 Gas Dryer Moisture Sensor Bar 3387223
Be SURE and read the Comments below this VIDEO for more help!
Anthony
Dec 20, 2017 | Whirlpool Dryers
I have a Kenmore Dryer Model 66832. One of its
Air restriction such as lint build up in the vent pipe. The wrong vent pipe (rigid metal 4" is recomended), not cleaning filter after every load. Filter/blower housing in need of removal and washing out. Faulty control thermostat.
Dec 24, 2009 | Kenmore 66832 Dryer
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Unable to locate lint filter
You can buy it online at this link below, just choose the color of your dryer..
Let me know if this is what you are looking for. Don't forget to rate me!!
Sep 13, 2009 | Kenmore 63942 Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Kenmore dryer
Take the filter out and remove those 2 phillips screws on the top.
Take the back off. Get the screws out the filter housing.Wiggle the housing over enough to remove the object.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Dryers Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
