Question about Maytag Washing Machines
F21 error on my maytag epic z washer, cleaned the drains? How to fix?
  • Susan Hayes
    Susan Hayes Dec 29, 2016
    We did this but it won't get passed the rinse and spin cycle and it does nothing.
    Top Expert:
  • Maytag Master
  • 79,865 Answers
Follow the link to the fix for this code. Front Load Washer Reviews
Posted on Dec 29, 2016
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Maytag Epic Z Washing Machine shuts down during spin, can I fix it myself?
Hello Brain;
My name is Peter. I am a retired field service appliance technician.
Error codes are generalized. Both of your codes are drain relative. They will tell you to clean your drain, but there is more to it than that.
You may have a bad drain water level switch, a plugged drain line....
Please send me your model number, So I can see what your have.
Peter Goodwin
Glen Burnie, MD
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
Maytag epic Z Washer shuts down at spin cycle
F21 usually indicates a pump problem however when that is not the problem then the place to look is the board itself as there is a mis communication between it and pump cycle? If the pump cannot operate it will not allow it to go into the spin.
Washer 4000 series 4.5 cu ft
The newer model Maytag washers are manufactured by Whirlpool and have Whirlpool parts. If this is a Maytag Epic model washerlb_icon1.png, "F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothinglb_icon1.png such as sock or under garments can commonly clog in this area as well causing the drain cycle to fail.
Nov 16, 2013 | Maytag Washing Machines
Maytag 3000 series washer F21
Just cleaned out the drain inside the Maytag 3000 and boy if that don't fix it nothing will. I think something was growing in there. Seems to be working fine now. Thanks for the help
Feb 03, 2013 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic z washer error code F21-have unplugged for 15 mins. and removed front panel and drained and found some coins and removed BUT it worked for a few mins. then the error code reappeared. what is...
F21 indicates a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump.
You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If this solution doesn't solve your problem, you may have to replace the drain pump.The error code will continue to appear until the pump is replaced.
Thank you !!
Aug 01, 2010 | Maytag Washing Machines
F21 ERROR CODE ON MAYTAG FRONT LOAD WASHER M#MHWE500VW
The newer model Maytag washers are manufactured by Whirlpool and have Whirlpool parts. If this is a Maytag Epic model washer, "F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as sock or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Dec 21, 2009 | Kitchen Ranges
I am getting error code F21
long drain time for the washer, it being an epic it should be under warranty call whirlpool at their toll free number depending where you live for free service
May 06, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
