Question about Plumbing
We have UPC kitchen faucet:WaterRidge NSF 61/9. plate is completely rotten,spray does not work. I think we are allegeable for faucet replacement because of life time warranty. sincerely, Yelena.
    Top Expert:
  • 50,023 Answers
Good luck with your "life" time warranty
contact the manufacturer if they are still in business and make a claim for a replacement or refund.
if it becomes too much of a hassle , junk it and get a n better make
Posted on Dec 28, 2016
  • yelena badura
    yelena badura Dec 29, 2016
    thanks. but we cannot find the faucet w/identical plate (2 holes) and do not have space on our stainless steel sink for an additional hole (soup dispenser).yelena
  • Bill Boyd Dec 29, 2016
    hardware shops have a limited product range
    the best place is a plumber supply shop where the tradesmen get their bits
    try taking your unit along as a sample as there may be a unit available that will fit straight in
I have a dripping WaterRidge NSF 61/9 . How do you fix this problem ?
On a water ridge kitchen faucet, there is a brass fitting that the water supply hose going to the faucet you pull out connects to under the sink, on that fitting youll find a small screw loosen it up, pull the fitting off , also loosen the other screw and disconnect the hose, now look inside the fitting there is some plastic junk ( not sure what its for) get a screw driver and a hammer and bash it out(not to hard) then put it back together. good to go, full pressure!! worked on mine and has for 2yrs.
Oct 25, 2017 | Computers & Internet
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
Am installing a new American Standard faucet. Does it need to be lubed prior to installation?
I think American Standard probably is correct, especially if there is a history of swivel faucets seizing over time.
Dec 11, 2013 | American Standard 4205.104.075 Reliant...
Waterridge kitchen faucet pull out
Hello, I would recommend replacing the faucet.
Sep 28, 2013 | Plumbing
Danze upc NSF 61/9 single lever faucet w/spray in head
I am in England and cannot buy a replacement nut. We lost the original one.where can I buy one? They don't do the right size in England!
Jan 23, 2012 | Danze Plumbing
Water is dripping out the back of the the Danza 61/9 kitchen faucet
Just in case you need to do so.
  1. Turn the water off. The water control knob is located under your sink and is connected to the drain. Turn it counterclockwise to turn off the water.
  2. 2
    Open the faucet to relieve any differences in pressure. Pull up on the faucet as you would if you were turning it on.
  3. 3
    Plug the drain of the sink with its stopper to prevent any parts from going down it.
  4. 4
    Turn the faucet handle sharply to one side to reveal a small cover plate. Pry the plate off carefully with a flat-bladed screwdriver.
  5. 5
    Unscrew the screw that is located behind the cover plate with a 4 mm allen key.
  6. 6
    Lift the handle off and remove the cap beneath it.
  7. 7
    Firmly grip the exposed cartridge with your hands and pull up to remove it.
Read more: How to Remove the Cartridge from a Danze D403412 ' eHow.com http://www.ehow.com/how_7640485_remove-cartridge-danze-d403412.html#ixzz1D76xWEgn I your case I think all you need are new o-ring seals on the spout. once you have the handle off and have gotten to the cartage grab the spout and turn back and forth while pulling up and remove the spout you will see the o-rings. I would get the repair kit before you start. The video below is not your brand faucet but the o-ring replacement is about the same. http://www.youtube.com/watch?v=AipEYoYiIhc
Feb 05, 2011 | Danze D403412 Melrose Single Handle...
Bought a home, main kitchen faucet is a Danze NSF
I'm not familiar with a NSF 61/9, but I've used several other models. I believe these are all ceramic disc valve. They almost never wear out. If you remove the handle and the trim cap or bonnet, there should be a nut or adjusting ring you can tighten. Don't over do it. The handle give you quite a bit more leverage than the small tap when it is removed. Here is Danze web site and you can look up your exact model number and see a exploded parts list: www.danze.com
Jul 12, 2010 | Danze Plumbing
Looking for parts breakdown picture for DANZE NSF 61 Kitchen Faucet Any Links?
NSF 61(-9) is a standard rather than the model number (it's often very difficult to identify the model number. If you are able to find the model number, the link attached has all the technical specs for Danze products (even discontinued ones). http://www.danze.com/tech_specs.asp
Otherwise, I suggest browsing their faucet section until you find yours.
Good luck.
Sep 13, 2009 | Plumbing
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
322 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
