Question about Kenmore Dryers
Can the filter be replaced on a Kenmore Dryer model #86573120. The cap has fallen off the filter and is missing.
    Top Expert:
  • Kenmore Master
  • 48,233 Answers
Contact your kenmore service agent and get a new filter and retainer cap
Posted on Dec 28, 2016
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
Kenmore Gas Dryer Model Number 110.70882990. I must replace the Fabric Dryer switch but am not able to remove the two plastic trim caps and end caps that hold the console panel together. Please help.
Iwopink --
First you need to remove all the sheet metal screws on the console back panel. The plastic side trim cap pieces are clip-fit. Look carefully at the dis-assembly diagrams online.
PDF service manual is available for download at:
Replacement parts are available from:
Owners manual is available at:
If you are still having problems, write back. -- SWT
Aug 22, 2010 | Kenmore 73952 Gas Dryer
It sounds like something has fallen down the dryer lint shoot. How do we remove the top to get to the issue?
I am guessing this is a kenmore/whirlpool dryer simply because of the problem. Yank out the filter,remove the screws on the top of filter housing. Use putty knife to pop top and then remove front. I have photos and manuals HERE
Mar 06, 2010 | Dryers
Running in a 30''vacuum
No. Sounds like you've got a plugged cap tube.
How careful were you when you silver soldered the new dryer onto the cap tube? It's real easy to get too much in there and plug the cap tube.
Dec 17, 2009 | Kenmore 77319 / 77304 Bottom Freezer...
Unable to locate lint filter
You can buy it online at this link below, just choose the color of your dryer..
Let me know if this is what you are looking for. Don't forget to rate me!!
Sep 13, 2009 | Kenmore 63942 Dryer
Kenmore HE2 Dryer Blades Loose
Yes. Depends on your model. The top, front and rear come off of some. Very easy fix. Your screws should be on the floor under the dryer.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kitchenaid dryer
Yank the filter out the top.
remove the 2 phillips screws in that filter housing on the top of the machine so you can pop the spring clips and get the top up. Remove the front and get the drum out. Oil the wheels and idler and rerout the belt using this PIC.
Jul 30, 2008 | Kenmore 62802 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
