Question about Refrigerators
I have a Toshiba Model GR-M55ADAWfridge. I want to know how to remove the cover of the ice maker in the freezer. The shelf is joined to it. I can't find a manual on line.
SOURCE: Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
Posted on Jun 10, 2008
lsteward68
  • 331 Answers
SOURCE: Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here
www.techray1.com and the link is on the guru guy on the left
Posted on Jun 15, 2009
woodchuck789
  • 4059 Answers
SOURCE: ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Posted on Jul 01, 2009
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Posted on Dec 14, 2009
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
Jul 06, 2011 | Amana ABB1927DE Bottom Freezer...
Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Jul 07, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker quit after my husband over filled the top shelf and blocked the air flow for the freezer. The freezer started to defrost itself and water was on the floor in front of the freezer. He unblocked...
Yes, If you will try a couple things. Fill ice maker with water and let freeze. Tell me if it will drop the ice when frozen, Let me know that and your model number. I am doing this to decide which one is the problem. The ice maker or the water control valve. Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replacing Defrost Heater and Bracket in Freezer Section of Fridge
I ended up having to remove things in this order: all shelves, ice maker insert, ice maker top ice tray, ice maker lower motor housing, shelving support rails (2), rear evaporator coil cover. This exposed the evaporator coils (which were already dry since the fridge had been off for two days) and most importantly, the defrost heater element below the coils. The heater element was easily unplugged from it's two connectors. I tested the unit with an ohm meter and it indicated it was open (infinity resistance). I then knew it was bad. I replaced it with a new unit and put everything back together in reverse order taking care to use the same screws. The fridge appears to be back in working order.
Oct 18, 2009 | GE Refrigerators
Ice maker is over filling
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Thanks
Aug 12, 2009 | Whirlpool Refrigerators
Ice Maker Overfills With Water
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
