Question about Dryers
Can the filter be replaced on this dryer. There is a filter but the cap has fallen off and is missing.
    New Friend:
What kind of dryer?
Posted on Dec 29, 2016
Gas cap tight and now will not close
What your saying is the gas cap is tight and still leaking gas?
Check the underside of the cap to see if the rubber gasket is missing.
it may of fallen off
Jul 11, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
LG DLG2524W gas dryer with check filter light on. Dryer will work but no heat. Totally vacuumed filter and filter area out. Opened cap on bottom side of dryer and vacuumed that out but still same thing....
It sounds like the high limit switch has tripped. You will need to disassemble the dryer to get to the switch to reset it. LG recommends replacing the high limit switch.
Aug 05, 2011 | LG Dryers
Homelite chain saw fuel system
The line at the back of the tank gets the filter (check it for plugging) and the one nearest the cap doesn't use a filter (it is the return line from the primer bulb). The filtered line goes directly to the carburetor inlet port and the outlet port allows fuel to be pulled through the carburetor and out to the primer port. Check and replace any fuel lines that are in poor condition. If the engine has been running with the intake filter missing, the interior of the carburetor may be full of debris. Remove, dismantle, and clean the carburetor interior. Go to: http://www.drystacked.com for an excellent 12 page article on Walbro carburetor theory and troubleshooting. Hope this helps!
May 31, 2010 | Homelite ZR10926 16 Chain Saw
1984 VT 500 C Shadow: 1983 honda shadow -starts and runs, seems to miss ...
The fuel filter is in the tank on the petcock and is self cleaning. I suspect you have bad spark plug caps on your bike the cap is part of the wire. If you remove the wire and take a reading with an ohm meter, the cap should read 5000 ohms . Anything above or below and you should replace the cap. This is probably causing the slight miss.
May 06, 2010 | 1984 Honda VT 500 C Shadow
It sounds like something has fallen down the dryer lint shoot. How do we remove the top to get to the issue?
I am guessing this is a kenmore/whirlpool dryer simply because of the problem. Yank out the filter,remove the screws on the top of filter housing. Use putty knife to pop top and then remove front. I have photos and manuals HERE
Mar 06, 2010 | Dryers
Zanussi FX 1265 W washing machine
You can seal the cap by some tape, but it is better to get a good replacement, for the filter needs periodic maintenance. Your machine will not drain well if the filter is clogged.
Nov 09, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Problem with Power up on PTD3500
Position reference device has probably fallen off the filter wheel, replace the filter wheel.
Sep 20, 2007 | Panasonic PT-D3500U Multimedia Projector
Dryers Logo
Top Dryers Experts
