Question about Homelite Garden
HOMELITE HGN1200B CARB SETTINGS - Homelite Garden
    Top Expert:
  • Homelite Master
  • 79,865 Answers
Posted on Dec 28, 2016
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Homelite Super ez auto starts, but when given throttle, it boggs down. carb is at correct settings. It idles well, but no throttle, but in a blue moon it wants to kick in for a second.
Have you changed the filter in the tank(if applicable). Also could need a carb rebuild kit. Sound like the diaprgams in the carb could be keeping up at a idle but not putting out enough fuel when you open up the throttle.
Sep 08, 2013 | Homelite Garden
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
I have a homelite weedeater i need the carb screw settings to adjust the carb
A good starting point is from a lightly seated position, back the Hi and Lo needles out about 1.5 turns each. From that point you can fine tune the machine.
This will help you:
http://www.zamacarb.com/tipspage.html
Aug 27, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
Carb settings for my Chainsaw
most all of them are 1 1/2 turns out from bottmed out which must be done gently to avoid bending the needle tip
Aug 13, 2009 | Garden
Homelite 26vt Mighty Lite carb settings
Setting up the carb right on a trimmer is like setting one up on an RC gas operated car. It takes someone with a good year,and a lot of experience doing it. If youre new at it,youre not just going to be able to get it tuned,well you could,if you want to spend a few hours. Just take it to someone who does it,they wont charge you much and it will save you a lot of aggrevation.
Aug 13, 2009 | Homelite Mighty Lite Lawn Trimmer
Gas floods out engine,if I pinch the line (regulate the flow) I can get saw to run.XL360 homelite
I sounds like there is some dirt under the needle valve in the carb. Change the fuel filter first, if it is falling apart then it is very likely a piece of it got in the carb. Try spraying some carb cleaner directly into the fuel inlet to see if you can flush it out first, If not then your going to have to pull the side closest to where the gas goes in off the carb take out the little screw and clean under the needle valve.
Mar 19, 2009 | Homelite Garden
Garden Logo
66 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
