Question about Locks & Locksmithing
Combination lock won't close - Locks & Locksmithing
2 Suggested Answers
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
Combination bike lock won't close
Lubricate the inside with WD-40 or similar, do the full combination and attempt again to close (DO NOT lock anything when trying this). If it still won't close buy a new lock.
May 27, 2017 | Cycling
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
Aug 27, 2011 | Locks & Locksmithing
I have a 175D combination lock. I recently changed the combination # and it worked in the morning and now does not close. Iv'e tried changing the combination but mstill won't close?
I hate to say this, because Masterlock makes a fine product: It sounds like something inside the wheel assembly is broken. If it's still under warranty, send it to Mster Lock for a replacement. If not, replace it with a Corbin Sesame. Corbin originated the design, and they've been making the lock for several decades, now.
Dec 09, 2010 | Master Lock 5400d: Portable Select Access...
How do you set the combination?
Open the lock with the existing combination. Inside the flap, you'll see a small chrome lever. Push the lever to the left (as you're looking into the box) and **** it up into the offset slot. This puts the lock into the "learn" mode. Select your new combination and rotate each wheel until the numbers line up at the opening index. Flip the lever out of the "learn" position, and back into the "home" position.
Test your new combination several times, before closing the door.
Nov 03, 2010 | Master Lock 5400d: Portable Select Access...
I don't remember the combination but it is open. please tell me how to set it
same problem with the spinner model.
My suitcase is open but since I dont have the lock combination (3 digits) I can't close it (not lock it, just close the case) . The combination changed when the case was open - is there a way to reset it ?
Mar 05, 2010 | Samsonite Tripod
Presto combination lock on a suitcase will not open
Jan 14, 2009 | Extensis Suitcase X1
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
factory to 0-0-0-0
(see instructions above)
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Locks & Locksmithing Logo
101 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
