Question about Xerox Phaser 6200DP Laser Printer
I have a phaser 6200dp It starts to miss align on the inside of the left, prints fine in the middle then miss aligns on the inside on the right. I have installed a new imaging unit to no avail I have tried recalibrating everything but the same thing happens giving it an out of focus look at the left and right of the page
  • 3 more comments
  • paul0 Jul 22, 2009
    I have already tried cleaning the transfer roller which looks in fair condition, I didnt want oto buy a new one only to find out that wasnt the problem, its starting to get a little costly!
    Hi Tried cleaning the rollers but still the same perfect in the middle but 2 mm out by the time it prints to both left and right edges
  • paul0 Jul 24, 2009
    Hi I have already calibrated the margins and they are aligned front and back perfectly but the print is still missaligned on the left and right hand sides of the page, I have now replaced the transfer roller again to no avail, what else can I try?
    No luck still prints perfect in the centre of the page but out of alignment at the left and right edges?
  • paul0 Jul 27, 2009
    Tried downloading new driver but the problem still remains anyone else have any ideas?
    President:
  • 3,278 Answers
Replace the toner cartridge
Posted on Jul 27, 2009
    President:
  • 1,734 Answers
If it does not help to clean the rolls and use a new toner cartridge, then you may use the wrong printer driver. Ensure that you have the latest version installed.
Find the drivers for all operating systems here:
http://www.support.xerox.com/go/go.asp?Xtype=download&prodID=6200&Xlang=en_US&Xcntry=USA
Posted on Jul 24, 2009
  • 158 Answers
I know you said you calibrated the printer. Did you go to the printer menu and print test page, and the print an alignment page. The alignment page will then ask you to input the best aligned images. Other than this, the printer heade may be straying. The guide bar that the head slides on may be bent or twisted. It can get twisted if someone pulls hard on a jammed paper. You may have to get a new guide bar.Please give me a positive vote if I have been at all helpful. Please let me know how it turns out. I am curious to know. Take care and good luck.
    President:
  • 1,462 Answers
The Calibrate Margins Menu allows you to adjust the printer's imaging area relative to the edges of the paper. Theimaging area is shown as a dashed rectangle; the printer will not print outside this rectangle.
Step 1. Adjust Side 1 Margins. To move the dashed rectangle to the position you want it on the page:
1. From the printer's front panel Support Menu, scroll to Improve Print Quality? and press OK.
2. Scroll to Calibrate Margins Menu and press OK. Select Print Calibrate Margins Page and press OK to print this page.
3. To move the dashed rectangle you see on the page printed to the position you want, use the front panel menu items Adjust Side 1 "A" Margin and Adjust Side 1 "B" Margin as illustrated below.
4. Reprint this page to verify the adjustment.You can adjust the settings from -40 to +40 units. The thickness of the rectangle's dashed lines is 1 unit. 6 units move the rectangle 1 mm. The maximum distance the rectangle can be moved (-40 to +40) is 6.7 mm.
Step 2. If the printer has the duplex option, adjust Side 2 Margins
1.
With Side 1 facing you, hold the print up to a strong light. Note the shadow of the solid lines printed on Side 2.
2. Use the front panel menu items Adjust Side 2 "A" Margin and Adjust Side 2 "B" Margin to move the Side 2 solid lines until they align with the Side 1 rectangle. Reprint to verify your adjustment
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Jul 22, 2009
    Genius:
  • 1,043 Answers
Some of these units have rollers made of rubber. Depending on how old your printer is, some of those rollers may have developed very smooth surfaces. The end result of that is the rollers no longer grip the paper as solid as they should. You then end up with a skewed paper trail. There are a number of conditioning liquids that are used to "rough" up the rubber rollers to restore their proper grip. If the path in question have rubber rollers, visit your local electronics store and purchase some of the liquid. If this fails to resolve the issue, you may have some issues with the timing of the rollers that move the paper. Depending on your experience you might want to test it or have your local repair center do so. Hopefully this will assist you in resolving your issue.
  • bvanjoff Jul 22, 2009
    When you cleaned the rollers did they look or feel that they were really smooth? It might be worth treating them with the liquid I had mentioned in the earlier post. The last time I bought some of the liquid it was under $10.00. I would never advise replacing any of the rollers unless they were actually damaged in some way. I know exactly what you mean when you speak of expense.
  • 453 Answers
The solution you tried by changing is a very step taken but if that has not helped you then the issue is with the roller unit installed in the system. Try to clean the roller unit. It must either be misaligned or worn out. In the first case it can be readjusted but in the latter case it would be preferable to replace the roller unit.
Kindly comment.
Posted on Jul 21, 2009
  • Sai Kiran Camsarapalli Jul 21, 2009
    Follow the solution below, sometimes its a simple matter of removing the trays and checking for paper in the way that may have fallen down behind the trays, also the rollers maybe loose or dirty or old, a good way to clean them is with a slightly damp cloth or some sticky tape, (this gives them some grip).
Wrong cartridge error code on canon pixma mp780 printer
Reseating the print head is seldomly needed to be done.Press the Open Button (1) to open the Paper Output Tray (2) Raise the Scanning Unit until it stops. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.The Print Head Holder moves to the middle Open the Inner Cover 1.Open the Inner Cover 2.CAUTION: a. Do not try to manually move or stop the Print Head Holder.b. Do not touch any metal parts.Press the ink tank's tab (1), then remove it from the slot (2) IMPORTANT:Handle ink tanks carefully to avoid staining clothing or the surrounding area. Lift up the lock lever and take out the print head.Again, place the print head back in position and press down the lock lever. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot IMPORTANT:a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.b. If the ink tank is inserted in the wrong slot, perform two head refreshings.Close the Inner Cover 2.Close the Inner Cover 1.Pull the Scanning Unit Lever towards you to close the Scanning Unit.Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.Automatically Aligning The Print Head Position:Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].Press <Menu> epeatedly until [MAINTENANCE] appears.Press left or right arrow to select [AUTO HEAD ALIGN].Press <OK>. The print head position alignment pattern prints.Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete. Manually Aligning The Print Head Position:When automatic alignment does not work well, align the print head position manually.Load A4- or letter-size plain paper in the paper support or cassette.Select the paper source with <Feed Switch> button.Press <Menu> repeatedly until [MAINTENANCE] appears.Use left or right arrow to select [ALIGN PRINT HEAD].Press <OK>. A horizontal pattern is printed.Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.A): Column(0): Select pattern number with most solid image Press <OK>.Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].Press left arrow. A vertical pattern is printed.Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.Press <OK> Repeat steps 12 and 13 to adjust column N.
Oct 09, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I just replaced the ink cartridge in my canon printer and tried to print something. A box came up saying the alignment may be off and I need to print an alignment page. How do I do that?
Hello. To do a head alignment follow the steps below.
  1. Click Start - Control Panel - printers and faxes
  2. RIGHT CLICK on the canon printer and select printing preferences
  3. Select Maintenance from the top right tab (see image below)
  4. Select print head alignment and follow the steps on screen.
I hope this helps, If so please rate this answer below. Thank You for supporting the FixYa Community
Regards GM
Apr 24, 2011 | Canon Pixma iP2600 Photo InkJet Printer
HP 1210 printer won't align. Pages come out misaligned at end of page.
You need to re-align your printer, please follow these steps:
XP/2000: Go to start > control panel > printers > right click your printer and choose properties, go to maintenance and choose "Print head alignment" follow the steps on the printed page and you will be fine.
Vista/7: Got to start > Devices and printers > right click your printer and choose properties, go to maintenance and choose "Print head alignment" follow the steps on the printed page and you will be fine.
In case the steps are unclear, you will have to put your printed page under the scanner and press the scan button.
Good luck.
May 30, 2010 | HP PSC 1210 All-In-One InkJet Printer
08,007.41:8472 It's a phaser 8400 i have no idea what to do..What could it be?
Your print head wiper blade is not moving properly.
The clutch that moves the wiper may be failing.
That blade is located between the drum and print head.
Printhead Wiper Alignment: Rotate the left and right idler gears until the Wiper is all the way to the bottom and the gears cannot be rotated further. Rotating the left and right gears together ensures that the wiper stays parallel and does not pop out of the belts. Now rotate the left idler gear a couple of teeth to raise the left side of the wiper to the top. Make sure that the left side of the wiper is a bit higher than the right side. Might have to try this procedure a couple of times, a couple of teeth at a time, to properly align the wiper.
Feb 08, 2010 | Xerox Phaser 8400 Laser Printer
The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Xerox phaser 6200 print double printing , what is the resion?
Do you have an imaging unit to replace? If that correct the issue great other wise you must replace fuser
Feb 26, 2009 | Xerox Phaser 6200DP Laser Printer
Printing on right side only
It is the carousel that is dislocated. Check the alignment if it's brooken
Nov 01, 2008 | HP LaserJet 2840 All-In-One Printer
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
Repeating defects appearing on every 3rd page
That most likely is on the transfer belt assembly, You can look at that belt and see if the defect is a mark that may be cleanable or actual damage to the transfer belt, which would require replacing the transfer belt.
Jun 02, 2008 | Xerox Phaser 6200DP Laser Printer
Xerox Phaser 6200DP Laser Printer Logo
139 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
