Question about Weedeater Garden
Weedeater leafblower barracuda 2595 user manual
  • Weedeater Master
  • 645 Answers
User Manuals Put in your model number and download from site.
Posted on Dec 13, 2017
5 Suggested Answers
  • 62 Answers
SOURCE: Featherlite Weedeater FL1500
Posted on Oct 08, 2008
  • 2841 Answers
SOURCE: How do I switch the
Your Barracuda has a inlet restrictor installed that must be removed when you use it as a vacuum. With the unit unplugged and off, open the inlet cover by inserting the tip of a screwdriver into the latch area on the vacuum inlet cover. Gently tilt handle of the screwdriver toward the front of the unit while pulling on the vacuum inlet cover with the other hand. Turn the inlet restrictor located inside counterclockwise to remove it from the unit. Do not close the inlet door. You will next attach the vacuum tubes. There are 2 tubes, a lower and upper. The upper tube is cut straight on both ends and attaches to the blower unit. The lower tube attaches to the upper tube and one end is cut at an angle. Locate the arrows on the upper tube and the arrows on the vacuum inlet areas. Line the arrows up and insert the tube into the opening on the unit and then twist clockwise until it seats. Install the collection bag over the blower outlet and secure with the velcro strap. You are now ready to use the unit. Here is the owner's manual with instructions and photos.
Posted on Oct 02, 2010
SOURCE: I need the spark plug
use a dime as a gauge filler. it worked for me.
Posted on Nov 20, 2010
  • 111 Answers
SOURCE: How do you attach the bag to the barracuda 2595
The motor housing has a spring loaded, hinged cover over the fan blades (so you don't chop your fingers off when using it as a blower). Open the cover using a screwdriver or narrow tool. Holding the cover open, attach the vacuum tube. Attach the collection bag to the discharge port (same place you attach the blower tubes) and secure in place using the velcro strip sewn onto the bag. Adjust the ******** the bag to fit your shoulder, turn power on and go. To empty the bag, just unzip the bag completely. Make sure you tighten the velcro strip so the bag doesn't come off while you are sucking up leaves.
Posted on Oct 11, 2011
check fuel lines inside fuel tank, see if will run on a shot of starting fluid e85 gas eats them
Sep 01, 2012 | Weedeater 2 Speed Gas Blower FL1500LE ()
Manual for barracuda sv22 gas blower vac
User Manuals
Just put in your model and download from this site.
May 21, 2012 | Weedeater Garden
Need to switch weed eater barricuda from blower to Vacuum but no manual
Here is where you can find the manual to download for the 2500 series Weed Eaater blower/vac
Aug 29, 2011 | RTO Weed Eater Electric Barracuda 2595...
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
I have a weedeater leaf blower that will start when I put gas in the caberator but will not run otherwise
sounds like the carby needs an overhaul. bellows in carby that **** up fuel may need replacing
Jun 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
I have a Weed Eater Barracuda leaf blower but don't have the manual. How do I attach the vacuum bag?
Copy and paste. It will take you to .pdf for your Barracuda
Apr 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
Garden Logo
153 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
