Instruction manual for hoop commander calculator
The machine had to be turned off while in the processing of doing a design. How can I get back to the last stitch so I can continue with the design?
I don't quite understand the question but I'll try to answer what I think you mean.
Most embroidery machines have a command pause and command backspace in order to go backwards to a point that you want to correct. To get it going again it has a continue command in order to get it going on again from the point you backed up to. It is unnecessary to remove the hoop in order to do this.
Aug 29, 2016 | Husqvarna Sewing Machines
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
Jul 30, 2015 | Baby Lock Esante
Diagnostic
There is no command called diagnostic in the whole manual nor in the catalog of available commands. This seems to be coming from the DiagnosticsOn or Diagnotics Off of the TI83/84 Plus calculators. Please read the manual to find out how is the correlation/factor determination coefficient (factor) are displayed.
Oct 02, 2013 | Casio FX-9860G Graphic Calculator
How do i calibrate the hoops on a baby lock emp6
This is a translation of instruction from the Service Manual for the Brother PR600, the twin of the Babylock EMP6. I will testify this works because I just did it to stop the insanity of my EMP6 thinking everything was a 5x7 hoop. If you look on page 4-36 of the free PR620 manual http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf you will find the same exact set of instructions that are in the PR600 manual. So here are the exact steps to augment the manual's instructions.
1. Turn off the machine.
2. Press all three buttons (start, threader and cutter) and keep them pressed while turning the machine on.
3. Press MAIN BOARD TEST MODE.
4. Press A/D TEST.
5. Put the largest hoop on the machine (7 7/8 x 11 3/4).
6. Press LL.
7. Put the smallest hoop on the machine (1 1/2 x 2 3/8).
8. Press S.
9. Take the smallest hoop off the machine.
10 Slide the arm to where the knob on the arm is when the large hoop is on the machine.
11 The reading on the screen should be very close to the value that is in the LL setting.
12 If not, go through the large hoop steps (5-6) again.
13 Slide the arm to where the knob on the arm is when the smallest hoop is on the machine.
14 The reading on the screen should be very close to the value that is in the S setting.
15 If not, go through the smallest hoop steps (7-8) again.
16 Press close when you have both settings close. They need not be identical but they do need to be no further than 200 away from the screen value.
17 Turn the machine off.
18 Turn the machine back on, load a file, and see if you have the same results that I had; it will show the proper hoops when you press the hoop symbol and it will also center itself in the hoop properly.
You can buy the PR600 service manual online for about $12. However, you have the 620 manual for free and there is really very little difference. I have found the manual invaluable in saving me trips to the shop and doing my own repairs.
Aug 26, 2013 | Baby Lock Sewing Machines
Janome Instruction Manual
Go on the web for janome sewing machines , pick you model and download service manual (pdf form)
May 15, 2013 | SewShop.com Janome Cord - 300E Power Cord
Bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
How can i find the % in the ti84 plus
Sorry, but that feature is not implemented on the TI84 family of calculators. No key or command will instruct the calculator to perform such a calculation.
You may deplore such a shortcoming, but please, do not hold me responsible for it.
Nov 29, 2010 | Texas Instruments TI-84 Plus Silver...
Instruction manual does not explain how to activate the calculator on the Toshiba Satellite P200D/P205D Series laptop.
Dear,
Just type CALC on run command at Start menu. Calculator will be opended on screen.
Click on START
then click on RUN
then type CALC
press OK
Regards
Apr 28, 2008 | Computers & Internet
22 people viewed this question
k24674
jasbo
jasbo
