WHERE CAN i FIND parts list for my faberwarehf919b
Lid is cracked that engages auto turn on
    Top Expert:
  • Washing Mach... Master
  • 78,289 Answers
You would need to contact the manufacturer for this part.
Posted on Dec 28, 2016
Where can i find parts for my faberwarehf919b oilless fryer
notify faberware---go online using make and model --or an appliance repair shop
Dec 28, 2016 | Washing Machines
Were is fuel pump relay Mitsubishi van 1988
The above answers probably are better that what I came up with. Manuals seem to be rare, or only for-sale rather than free online. That said, i looked at a local auto-parts store, and they have listings like these (
List Fuel Pump Relay 1988 Mitsubishi Van Reilly Auto Parts ) for the fuel pump relay. If the panel doesn't have listings in the lid for what is what, you may be able to use the picture in the link to narrow down which relay you're looking for. Good Luck!
Nov 18, 2015 | Mitsubishi Cars & Trucks
My Whirlpool WTW57ESVW1 is not working. The auto load sensing stopped working long ago. When i shut the lid it won't start. Sometimes if I slam it shut it will work but now I have nothing help!
Here is a list of possible Parts that can be replaced for this symptom.
  1. Lid strike
  2. Lid switch assembly
  3. Motor Coupler
  4. Motor Capacitor
and you could also replace the Load Sensing Switch if you needed. The pictures are in the same order.
Check parts and replace as necessary. I am also including a link to the parts diagram.
Good Luck!
JP
WHIRLPOOL AUTOMATIC WASHER Parts Model WTW57ESVW1 Sears PartsDirect
Jul 09, 2015 | Whirlpool Washing Machines
Where can I get a replacement lid hand for my Rival slow cooker model no scv655?
Rival is now Crock-pot.com. Their parts page for your model shows no parts, but they list a toll-free number you can call. Try that and see if they have a different model lid or handle that will work.
When a friend's cooker lid needed a handle, I picked up a plain round wooden drawer pull at Home Depot, used a wood rasp to round the end of the knob a little to fit the curve of the lid, and put thin rubber washers from the plumbing aisle under the screw head and between the knob and lid so I wouldn't crack the glass when tightening the screw for a snug fit. Nearly two years now and it's still holding on. If you can't get an original replacement part, maybe you can roll your own.
Mar 03, 2011 | Rival SCV655 687Quart Slow Cooker
Whirlpool Untilmate care II Quiet Wash - Mod # LSQ9200PQ0: Spotaically does not engage in Hi Spin after drain. Motor is running, but basket is not engaged. If you raise the lid (and see that it is not...
The problem is commonly attributed to either a loose/defective lid switch, or a worn clutch/brake assembly.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid switch on the model number you provided is located near the left lid hinge under the console. It is listed as item number 11 under the "Top and Cabinet" parts listing at the websites I provided you. The part number is 8318084. Prices will vary between sites so shop and compare.
The brake/clutch can become worn and the small brake pads will glaze or wear down to the point that it will no longer engage properly and slip. The brake/clutch assembly comes as a complete kit and can be replaced by following the steps provided in this link:
http://www.fixya.com/support/r4249301-replacing_clutch_whirlpool_top_loader
There are helpful exploded view parts illustrations to assist you at the first three website I have listed. The complete clutch assembly is listed as item number 5 under the "Brake, Clutch, Gearcase, Motor and Pump" parts listing. The part number is 285785.
If you have questions, or need additional assistance, please post back and let me know. These are simple repairs that you can easily perform without the assistance of a repairman.
If you have any questions, please post back and let me know. I hope this helps you.
Dec 16, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer was running then we heard a thump and it wont turn on at all. Is it the belt??
Many dryers have an auto shutoff mode when the belt breaks. Lift the lid to inspect.Generally you will have to remove several screws in the door area to release the lid. You will need to slid a putty knife into the front corners and pop the spring latches to release the lid. Be careful not to crack the enael on the lid and housing when prying
Sep 13, 2009 | Dryers
Where is the trunk lid pull-down switch located?
look for the little motor and make sure the little drive gears are ok and not damage in any way. here is a place that only sells GM parts only and it schram auto & truck parts and the #1-800-292-1032
Feb 11, 2009 | 1990 Cadillac Eldorado
Need another lid
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Jun 01, 2008 | West Bend 41062 Bread & Dough Maker
Bread maker lid has crack in plastic
I would try www.esalton.com They are the manufacturers and you should be able to call their customer service number for parts. Good Luck!
Bekkah
Bread-maker.net
Nov 07, 2007 | Breadman TR850 Plus Bread Maker
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
