Question about Belling Dishwashers
My belling integrated dishwasher is leaving everything very wet .... previous dishwashers always dried contents very well .... have tried different cycles with same result
rockitman187
  • 2559 Answers
SOURCE: My brand new dishwasher leaves white film
The new washer is drying the dishes faster that the old one,Try setting it to no heat dry and see if that helps,if so you will need a water softener or filter for the water line to the washer.
Posted on Jul 29, 2009
  • 120 Answers
SOURCE: Smeg integrated dishwasher continually washing -
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Posted on Nov 03, 2009
erpaalai
  • 999 Answers
SOURCE: My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Posted on Jan 05, 2010
SOURCE: Dishwasher not drying
the dishwasher does not have a heating element to dry the dishes. If you wash glass or ceramic dishes and cups then the rinse cycle makes them hot enough to dry without a heating element but if you wash a lot of plastic this process does not work very well. Open the door after the load is washed and leave them to air dry for several hours and you will be fine.
The manual states that there is no heating element to dry dishes. The high heat content of porcelain, glass, or metal dishes enables them to get hot and stay hot long enough to get dry without a heater. Plastic does not have nearly as high a heat content so they cool down much more quickly and don't get dry.
Posted on Jan 10, 2010
  • 1456 Answers
SOURCE: I have a new stainless
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Posted on Sep 07, 2011
Kenmore dishwasher leaving a lot of water on door, bottom, wall and dishes! it STINKS!
The pump could be leaking. The drain could be plugged - hence the smell. Taking a look underneath could reveal what needs to be fixed. I don't have an answer for why dishes are still wet even after a hot wash and heated dry but perhaps it is related to the other problem
Oct 22, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Our dishwasher is about 3 years old. Our only problem is that when it is finished washing everything is clean but very wet. We always have to dry everything. Is there an easy solution to this problem? ...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 14, 2011 | Bosch Dishwashers
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 23, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
How do you get the washer to dry dishes? What
Check the operators' manual.Don't use the drying element as it's costly on the electric bill.When the washing cycle is complete leave the door partially open and let the water evaporate
Sep 28, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Dishes still wet
You need a new heater element . Get engineer to fit for you.Cheers,Derek.
May 19, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
