Question about Garden
Fuel filter for Mac 110 model # 600016C and a parts manual ?
2 Suggested Answers
emissionwiz
  • 77499 Answers
SOURCE: Mac 110 McCulloch chain saw model # 600016C need a fuel filter and would like a parts manual
Go to www.searspartsdirect.com
Posted on Dec 28, 2016
Testimonial: "thanks"
Trying to find parts for a MAC 110/Model 60016C McCulloch chainsaw
Here's a link to your chain saw. Model Profile MAC 110 Parts are very hard to find for these .I think they went out of business.
Oct 04, 2016 | McCulloch Garden
Hello,I have Mac 110 model#600016c It`s in need of a little TLC The saw is about 25yrs.old and has never hadany work done on it.I need to know what the spark plug gap should be and what the gas/oil mix...
Spark plug gap should be: 0.020" and the fuel to oil ratio is 40:1. Be sure to use fresh fuel and a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Mix well in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
McCulloch Mac 110 saw 600016C 14-852292 Manual
go this free manual site,no crappy ads just asks for 1 answer when you download a manual. it is a great resource
http://www.manualsonline.com/
Sep 10, 2010 | Garden
I have an old mac 110. I believe I need the chain tension adjuster as I am not seeing how to tighten the chain. I can't find my manual so I don't have a part list.
Loosen 2 nuts that are on middle of inside end of bar closest to motor, on retaining plate. Dig out shavings & dirt on outside of that plate there is a recess hole. In it is a adjustment screw to tighten chain. Screw in till it takes up the slack in chain. Retighten 2 nuts when finished.
Jun 30, 2010 | McCulloch Garden
My 110 model chain saw sucks chain oil back into the piston cylinder. When I remove the spark plug and pull the cord it spews out red chain oil. What is the remedy
Did you adjust the oiler? To far CW might cause this. The automatic oiler is driven by an impulse line from the crankcase. If the piston assembly is to deep or has failed there is a direct line into the crankcase.
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Mac 110” 600016C may also be a _# instead of letter 600016_03) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Mac 110” IPL number = 11-600016C). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
This is a little complicated so I am going in small steps.
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “11-600016Letter or YourDashNumber”
Every Oil Pump will eventually cross to
Entire pump assembly:
219989 Kit Pump Assy (Oil) $9.29
O-ring
110653 O Ring $0.75
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
I have found McCulloch parts here I can get no where else and they are reasonable.
You can download a complete parts breakdown for your saw here using the IPL constructed above:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
Please see if the parts you need are available here. They were not when I ordered them but it is a nice way to say thanks for providing the IPL. I hope you find this helpful.
Lou
Dec 18, 2009 | McCulloch Garden
I need an owners manual for McCulloch 100 series Eager ****** chainsaw
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
A complete parts list using the "IPL Number" can be found here:
K&T Parts House
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
ArboristSite is where I found both my Mac 110 and Power Mac 320 operators manuals.
Dec 13, 2009 | McCulloch Garden
I have a McCulloch MAC 110, Model 600016C which
The IPL (exploded parts list) for your saw can be found here:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600016C_MAC_110_01_77_to_02_83_IPL_95807_R2.pdf
Page 6 item 21.
You have to remove the engine to access it.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
There is some discussion about the proceedure in the McCulloch thread. Its a good little saw. I'm awaiting oiler parts on mine. HTH
Lou
Oct 03, 2009 | Garden
Mcculoch mini mac need owners manual model 600030g
I have a 600016C. I found my manual here:
Beg for manuals thread (ArboristSite)
If you need to join to post your request it is free. They are a good collection of chainsaw enthusiasts. GL
Lou
I tried a search for McCulloch 600030G & 600030G without a hit. Post it; someone has what you need.
Sep 21, 2009 | McCulloch Garden
Sawwon't start or run
On my 110 you take off the front section of the saw body to get et the fuel tank and remove it to get at the fuel line. There isn't much room to work in there so be patient.I'll bet your carb needs new diapragms I bought my manual on e-bay.hope this helps
Sep 08, 2009 | McCulloch Garden
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
