Question about Miscellaneous
Waupaca 3 stop elevator. Power went out. Stuck between floors. How reset elevator to get to proper floors?
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
There should be an escape hatch above your head on the ceiling panel. Try that but be careful. If not, pick up that phone next to the floor numbers and call the fire department.
Posted on Feb 03, 2017
Endurance xt3300
follow the steps and fix it. God bless you. You have 2 alternatives with this error.
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jun 19, 2013 | Exercise & Fitness
What are the benefits of using an elevated dog bowl?
There are plenty of benefits for using elevated bowls for dogs:
  • For older dogs, eating from an elevated bowl puts less strain on the joints and hip and allow the dogs to use a more proper posture when eating.
  • Elevated bowls are more stable compared to bowls that are on the floor.
  • The dog owner doesn't have to bend down as much to fill up the bowl. This can be really beneficial for older people with back problems.
  • Elevated bowls allow for better digestion because they minimize the amount of air that dogs swallow when they chew their food.
  • Elevated bowls are cleaner compared to bowls that are on the floor. Also, dogs tend to make less mess when drinking out of an elevated bowl compared to ground-level bowls.
  • It is recommended by veterinarians for large and old dogs.
Sep 02, 2012 | Alessi Pets - Others
My cardiozone supersport HR club II started elevating by itself to highest level then stopped running but stay elevated. Could not get it to return to lowest level, just stuck there. I got an E7 code on...
Sounds like the motor control board went wacko.....ran the incline motor all the way up and shut down the treadmill motor for no reason....sounds like a control board problem...
Dec 15, 2010 | Sport & Outdoor - Others
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
Each morning a man leaves his apartment on the 24th. floor, goes to the elevator pushes the button for the 1st. floor gets in and goes down to the 1st. floor leaves to go to work. Each afternoon he returns...
Here is your solution....
Because he is a lilliputian. He is so small that he can not reach all buttons of the elevator. In the morning he can go the ground floor, because the ground floor button is below. But when he comes home he can only go the 23rd floor, because he can not reach the other buttons. Thanks in advance, -->
Aug 24, 2009 | Texas Instruments World of Mathematics...
Bizhub 350 erro code c1183
Elevator motor ascent/
descent drive failure
• The elevator tray lower limit sensor (PC13) is not turned ON
even after the set period of time has elapsed after the main
power switch is set to ON.
• The elevator tray home position sensor (PC11) and elevator
top face detection sensor (PC12) are not turned ON even
after the set period of time has elapsed after the elevator
motor (M11) is energized.
• The elevator tray does not stop at the position for the specified
tray after the elevator motor (M11) is energized (beginning of
descent operation) and the elevator tray lower limit sensor
(PC13) is turned ON.
• The elevator top face detection sensor (PC12) is not turned
ON even after the set period of time has elapsed after the elevator
motor (M11) is energized (beginning of ascent operation)
when paper is being fed out.
May 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Miscellaneous Logo
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
