Question about Brother Sewing Machines
Can I use a 1-step button hole foot on a brother LS14 sewing machine?
  • Brother Master
  • 11,749 Answers
It would probably be easiest and fastest to contact your local Brother dealer. If your machine can use the unit, you can probably buy it directly from the dealer.
Posted on Dec 29, 2016
helale
  • 3 Answers
SOURCE: One step button Hole V for Singer Sewing Machine
Hi, I had the same problem, but I finally found my manual. The solution is that you have to use the presser foot for buttonholes but the most important part is that you have to lower the buttonholer lever. It is located right next to the needle to the left. It is a metal lever with a little square white plastic end. You need to pull that down in order the the buttonhole feature to work. My button was too big for the buttonhole presser foot, so I had to use the regular presser foot, but hit the buttonhole lever with my had to make it go up or down.
Posted on Oct 28, 2008
SOURCE: Attaching fit button-hole foot?
Just pull down on the original metal foot. It will snap off and then you can snap on the button hole foot. Good luck!
Trudy
Posted on Dec 02, 2008
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
SOURCE: How do you sew button holes?
I am assuming that you have marked where you want the button hole to be. Here is the link to the manual for the 5050.
446_5040_5050[1].pdf The instructions for making a buttonhole are on page 36
Posted on Apr 21, 2009
  • 76 Answers
SOURCE: brothers sewing machine ls 1520
I hope this is your machine, check it out
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1520_EN_270.PDF
ACCESSORIES
1 Buttonhole foot (1 pc.)
2 Zipper foot (1 pc.)
3 Button sewing Foot (1 pc.)
4 Needle set (regular single needle No. 14) (3 pcs.)
5 Twin needle (1 pc.)
6 Bobbins (3 pcs.)
7 Darning plate (1 pc.)
8 Screwdriver (1 pc.)
9 Extra spool pin (1 pc.)
Parts code for zigzag presser foot: 138135-051
Foot controller: X57319-051 (110/120V Area)
XA6422-021 (220/240V Area)
XA6412-021 (U.K.)
XA6414-021 (Australia, New Zealand)
The above accessories are stored in the accessory bag inside the
extension table. These accessories have been designed to help
complete most sewing tasks.
Posted on Aug 28, 2009
I have a brother ls14 machine and i bought a WALKING FOOT FOR IT BUT WHEN attached the needle screw catches on it when trying to sew.
Be sure the "fork" is around the needle clamp screw. If that is not possible, then you possibly have the wrong foot for your machine.
How do attach the walking foot Brother
This is the foot you should have and how it should look when installed:
https://www.brothermachines.com/sewing/218/Walking_Foot_(Brother)_-_F034N
Oct 24, 2017 | Brother Sewing Machines
Just put my button hole foot on for the first time ready to practise a button hole but it just keeps beeping any ideas?
Yes, you need to review the steps to sew a button hole, because just putting on the foot is not enough. Generally there are several other things that must be set before it will actually sew buttonholes. Download your user's manual free at the Singer Sewing machine website, and review it.
Jun 09, 2014 | Singer Confidence 7463 Computerized Sewing...
Cannot reset buttonhole size
Assuming its a singer domestic machine
1.For a 1 step buttonhole, you will need to place and lock the actual button at the buttonhole foot holder(back end of the foot), the size will remain the same each time you sew a button hole.
2.For a 4 step buttonhole, the size is determine by sliding the foot against the line/marker which you can see on the foot itself each time you start to sew the button hole.
Aug 21, 2013 | Sewing Machines
Missing accessories
Call Brother Sewing Machines - 1-877-276-8437
Jul 01, 2017 | Brother Sewing Machines
One step buttonhole help!!
On my machines, the one step button hole requires a pull down sensor that the button hole foot triggers when it has done one side. You put the button in the holder part of the button hole foot, set up with sensor and start to sew, being careful not to touch the trigger, then the machine will sew the required length, change stitch and then do other side. Maybe there's a demo on you tube ? I hope this helps
Sep 04, 2010 | Janome Sewist 525S Mechanical Sewing...
Brothers sewing machine ls 1520 what all parts came with this machine.did it come with a button hole foot
ACCESSORIES
6 Bobbins (3 pcs.)
XA6412-021 (U.K.)
Aug 27, 2009 | Brother Sewing Machines
What type /size bubbin does the 808 brothers sewing machine use. Does this machine also sew button holes ? I have a older machine with no maunal
It takes a class 15 metal bobbin, yes it can do buttonholes you just need a buttonhole foot on the machine
Jul 16, 2009 | Brother PC-6000 Pacesetter
One step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
May 15, 2009 | Singer 7422
Can't get buttonhole setting
To the left of the presser foot, there is a plastic button hold guide that must be puled down in order to sew a button hole. Make sure the arm is pulled completely down and placed behind the guide on the foot. There's pictures in the manual, or you can find the manual on-line at brother.com. I hope that helps!
Mar 30, 2009 | Brother CS-8072 Computerized Sewing...
Sewing Machines Logo
26 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
