Question about Sewing Machines
My Hoover Windtunnel sucks air IN the hole that is supposed to blow air into the clear "bag." I have only used it twice. I have cleaned the filter and emptied the dirt container. Help?
It worked before, and I don't remember doing anything different. Is there a button that reverses everything that I might have pushed accidentlally?
SOURCE: reverse on kenmore sewing machine 385
I recommend that the machine be serviced by a professional but if you're handy it may simply need cleaning around the reverse cam. To do this place the machine on it's back. You'll need to access the rod that drives the feed dogs and cam mechanism by removing all screws holding the bottom plate of the machine. Remove the bottom plate. Note that when you push the reverse button, while turning the wheel a thin rod moves left which allows a plastic cam mounted to the cam rod to also move left and engages the feed dogs in reverse. If the cam is not moving enough or if too slow, it may be that the rod and cam need cleaning and lubrication. Clean out all lint and lubricate the cam where it moves on the shaft. Try to get it to move more freely without forcing it. When done replace the bottom plate. I just repaired my wifes machine and this solved the problem. Hope it helps.
Posted on Feb 17, 2008
  • 46 Answers
SOURCE: Automatic Button Hole
perhaps look up the user manual online, or get in touch with your local dealer.
Posted on Oct 24, 2008
  • 192 Answers
SOURCE: button holes husqvarna 6440
Use the "C" foot.
Set the "Stitch Width" dial to 0, then pull it out. You will now be able to rotate the knob and, if it is working properly, you will get the 4 parts of the buttonhole. Rotate to 1 and sew the left column, 2 for a bar tack, 3 for the right column coming down the other side and 4 should close it off.
The knob may be rotated back around to start another buttonhole by rotating forward. When it is pulled out, it will not stop turning at 4.
Always set the know to 0 to pull it out or push in.
Posted on Aug 21, 2009
  • 5 Answers
SOURCE: I can't remember how to sew a button hole....lost
I have a 180e, but cant put my hand on the manual tonight to clarify this issue for you.
From memory though, you need to go into the button hole button option, & look for stitch #60. The button sew application is automatic & its recommended that the #18 button foot be used.
As I said, that is from memory. Will check my manual asap & will clarify anything if needed, but I'm pretty sure thats the procedure, as I sewed buttons not that long ago. Hope this helps you.
Posted on Oct 04, 2009
Tally Girl
  • 1125 Answers
SOURCE: I can''t remember the steps
you can download a manual for the Activa 145 here, buttonholing steps would probably be very similar for your model
http://www.bernina.com.au/webautor-data/888/0305295204_0303_a135-a145_EN.pdf
It says you sew one bar, then press the reverse button and the automatic function then sews the bar tacs, other side, bar tack and finishes.
Posted on May 05, 2011
How do I open the top of the machine to clean thread etc.?
try a can of compressed air to blow it out .
Oct 31, 2015 | Sewing Machines
Hi! I have a janome dsk30 that keeps beeping with the foot control light flashing. The only way to clear it seems to be to unplug the control foot and plug in again -any ideas?
Sounds like it is getting too hot if it is OK after unplugging. Is something stuck in your foot pedal? Give it a clean and hoover as dust and threads can get stuck there. Good luck
Apr 29, 2015 | Janome Sewing Machines
How can I clean the upper thread sensor? My machine continually throws a "Check upper thread" error, even though the upper thread is fine. It seems the sensor is not "Seeing" it.
Try using waxed dental floss to dislodge the snag. Gently pull the floss toward the needle through the thread path. You might have to do it several times. You can use canned air to blow the lint out of the machine. Then make sure you are using a good quality thread. Avoid those cheap spools of thread because they usually are not spun tightly enough to prevent lint build up in the thread path.
Dec 30, 2013 | Brother PE770 Computerized Sewing Machine
Machine is not cutting as it did. When I try to sew the threads are sucked down inside, tangle and jam the machine.
try a new needle
also clean under the needle plate & bobbin area for loose threads & lint
sometimes using a can of computer air work good
also mak
Aug 10, 2011 | Juki TL-98Q
My Imagine Serger's threading ports are blowing out air when I press the lever, not sucking the thread back in.
Hello Wardmel
Make sure that the serger is set up for threading, now check that the air tubes are not plugged. You should have a long spun wire to clear the air paths.
Happy Stitching
Sewingirl/
Jun 30, 2011 | Baby Lock Imagine
Vacuum motor runs but little or no vacuum. Does not pick any dirty water
Hi, You need to Check :- 1. Belt 2. Bag 3. Switch For Floors 4. Hose ( Clog in hose is one of the common Reasons ) 5. Check Clear Tubes ( Refer to the Manual ) For the 5th point i mentioned, let me provide an example :- http://www.eureka.com/service/manuals/70750.pdf Check Page 10. Let me know, if needed further assistance. Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
Feb 11, 2010 | Sewing Machines
When I try to thread the right looper, I cant get it to go down the hole. the one on the left goes in just fine. I have always pushed the thread down just so far, then push the button for the air to push...
Hi, I have a Babylock Imagine, but had exactly the same problem so found your question when looking around. After tinkering for a bit, I figured out that there was a thread stuck somewhere between the air threading hole and the lower looper eye, and it was causing the air to blow backwards. I pulled the thread out and everything started working correctly. Looks like the Evolve is set up similarly--pull down the front cover, then pull the needle cover down and see if you see anything caught in there.
Aug 02, 2009 | Baby Lock Evolve
I have a singer 301 that I took the throat plate off to clean and put it back together with the finger in the notch like it is suppose to be but it will not sew just locks up what do I need to do
most likely, you have a small piece of thread caught between the hook assembly and the bobbin case base. you can try to unlock the machine by holding the position finger with your left hand and turn the handwheel backwards. If it unlocks, use a can of canned air to blow it out.
Jun 09, 2009 | Bernina Artista 180
Button hole problem
What ever you do DON'T FORCE IT. I see these problems when a buttonhole mechanism hasn't been used for a long time or the machine has been dropped. There is a cam follower (like a finger) that changes positions when you turn the knob. This could be out of place and a tech will have to go in and fix it.
OR old oil has hardend from non-use or grime has acumulated in the mechanism and jamming it up. I sometimes have luck cleaning it with Tri-Flow oil (hardware stores) but again this may be a tech job also.
Jul 25, 2008 | Sewing Machines
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
