Question about The Toys
How can I reset the leader board on my Lexibook Countdown game?
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
My lexibook master tablet will not turn on or charge
If your power adapter is definitely good then it appears that your tablet is ng since it will not turn on or charge the battery.
Nov 09, 2015 | Lexibook 7" Tablet Master in English...
I forgot my password for my lexibook laptop
if it was administrator....then format the laptop
Aug 16, 2012 | Lexibook Mfc105gb Laptop Master 7 Gb...
Just need to get the manual/instruction leaflet. please advise from where
You can find user manuals for all lexibook toys at this link: User Manuals
Mar 03, 2011 | Lexibook Toys
My Son has the Lexibook Laptop Master MFC110GB and has entered a password but forgotten it, Help please
Ask him what his favorite game is or color, car, pets name, girlfriend etc and see if you can resolve it. Otherwise, you may have to get in touch with support for that brand and see if they offer a master reset disc. They do turn up on ebay as well
Oct 30, 2010 | Computers & Internet
Toys Logo
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
