Question about Mitsubishi Televison & Video
Where is the DM module on a mitsubishi wd-52627
  • yadayada
    yadayada Dec 28, 2016
    DM?? Not sure what board you refer to here.
5 Suggested Answers
  • 1779 Answers
SOURCE: location of dm module on wd-62725 mitsubishi 60
The digital module is bolted onto the light engine. If you are not a tech, you are in for a real treat. I checked for availability and it said No Longer Available. They want the DLP sets off the market.
Posted on Jul 03, 2009
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd-52627 dlp hdtv doesn't appaer as
I have seen alot of the Mitsubishi DLPs to get very dim and the colors appear dull and the cause was almost always caused by the small front mirror needing to be cleaned due to a dust build up. If you need assistance with how to access the mirror on that model send me a email and I will send you info on how to access the mirror. The file is too large to post here. slinteriors@yahoo.com
Posted on Jun 08, 2011
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WD-52725 DLP DM board
The DM boards for that chassis are almost impossible to find if they are still good. Have you tried replacing the caps on the DM board that you have? Thats usually whats wrong are bad caps.
Posted on Mar 16, 2012
Testimonial: "Hi. Thanks for the info. I did find one cap that domed and replaced it. Not knowing that you had to wait and hit a reset button. I ordered 12 caps that are mentioned in other posts. We'll see what happens then. Thank you again."
SD Tech
  • 14553 Answers
SOURCE: Where is the DM Module on a Mitsubishi WD-62528?
A few pieces of advice--the boards are sandwiched in the main signal chassis and not easy to get at.
If you have replaced those 4 in the actual power supply they do for some models sell the entire signal chassis (has almost everything except the optical light engine) for about 250 exchange.
Let me know what issues you have and I may have suggestions--this model has one very odd issue that is simple---picture gets so dark it is hard to see--not the lamp but easy to fix.
Posted on May 27, 2012
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
Mar 16, 2012 | Mitsubishi WD-52725 52". Rear Projection...
We lost power the other night. Now I have a continuous green blinking light and it won't turn on. I have tried everything the manual says.
Try Going To The Mitsubishi Web Site. Downloading The Mitsubishi Service Manuals If You Don't Already Have It. It Will recommend The parts You Need To ordering. Circuit board photos are also shown which provide a visual reference during the repair process.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
Sep 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-52627 dlp hdtv doesn't appaer as
Jun 07, 2011 | Mitsubishi Televison & Video
Hi i have a mitsubishi WD-52525 and the timer light just keeps flashing and the tv wont power on....whats wrong with it?
Check for bad cap on DM & FMT modules 1000uf at 25volts caps to E2P module.
Credit: http://www.repairworld.com
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Had a new dm module put in. TV does not show device menu when I push remote.
This set like most of them has a reset--yours has a soft and a hard reset----try the soft reset first--
(with set on) Menu, 1,2,3 enter.
Let me know what happens.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WD-52627 52" Television
Where is the ballast board on a Mits. WD-52627
In order to reach ballast you have to remove optical block. Ballast is usually covered with metal shield. It's located on the right hand side of optical block (if to look from the back of the TV). and it have two black thick short wires that connected to the lamp cartridge socket.
Regards.
Russ.
Aug 12, 2010 | Mitsubishi WD-52627 52" Television
Hi, I have a Mitsubishi WD-52525, and have the Green Light of Death. I plan on replacing the capacitors, and have the Power Chassis out of the TV. However, I am having issues extracting the DM module...
The DM is the second board in the chassis from the right side looking in the rear. The first board is the FMT. The second is the DM, third is the Signal and the one which is sideway across the front is the Power board. The Chassis metal shields have to be removed to access the boards.
Dec 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
