Question about Refrigerators
Can't get the water filter to eject. mod krsf505ESS00
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
What is the model number for the water filter for the KitchenAid #KSRG25FKSS16 refrigeator and where is it found in the refrigerator? thank you.
Hello pssutherland,
I understand that you need to locate the water filter on your KitchenAid fridge. The water filter is located at the bottom of the fridge in the grill. There is a eject button that you will need to press next to the water filter in order to get it to release.
1. Press the eject button
2. pull the filter straight out
3. Remove the cap by turning it clockwise (you will need to install this on the new one)
4. Reinstall the cap on the new filter
5. Push the filter in until the eject button pops back out.
6. Purge the system run three full glass of water thru the water dispencer and throw away.
7. You are done
Thank you for choosing FixYa.com
Justin
May 11, 2011 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Fridge Mod-ED20TQXFX01. No water is coming into ice maker. Removed plug from water supply solenoid and applied power-water then flows into tray. Arm is down on ice maker.
Sounds like a solenoid problem. An electrical valve that opens to allow water into the tray(s), then closes when they are full (usually by a timer). The valve may be defective or the control circuit for the valve. A plugged filter could cause symptoms like this too, but you will usually have some water coming out into the trays.
But with no water and the fact that you had to apply power before water flowed into the tray, then it is the solenoid.....
Sep 11, 2010 | Whirlpool Refrigerators
Replaced a waterfilter in my ref with wrong filter model
The new filter you used will not damage anything in the refrigerator, the only difference will be in the fill rate, it may fill slower than you like.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
Water filter does not eject when button is depressed.
I just had the same ting happen to me. You need to leave the cover to the water filter (it is the black plastic cover that is part of the grill) is still connected to the filter. After depressing the eject button, this cap helps to pull out the filter. DON'T throw away this very important part, other wise it is impossible to get the filter out. Once you eject the filter, some water will leak from the filter. Just put it in the sink to drain for a while.
Apr 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Location of eject button for water filter
For more information or advice regarding water filters visit www.h2ofiltercentre.com it’s the best place I know to find affordable water filters and advice in the UK.
Call 01273 74 74 77
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Cannot locate water filter eject button
your water filter is located in the kickplate area, you either have to twist it counter clock wise , or rightnext to the filter is a little button says PUSH. it ejects the PUR filter for replacement . ordering instuctions on filter itself
Mar 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Filter ejection
it shoulnt eject they are usally screwed on
Dec 14, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
