Question about Philips Health & Beauty
Hi I have a Philips Sensotouch 3D shaver and when I switch it on down the bottom a picture of the shaver head circled by two red flashing arrows comes on. What is this problem please.
  • yadayada
    yadayada Dec 28, 2016
    Hi Dennis McNaughton, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
ctf1800
  • 4402 Answers
SOURCE: philips 37pf9631d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
SOURCE: Philips cool skin shaver fault
The shaver head symbol means the motor isn't starting, which all the support info assumes is because the heads are too gunked up with hair and congealed moisturizer etc, so clean it. In my case it was because the motor had seized - I completely dismantled the razor and turned the cog attached to the motor spindle by hand while turning the razor on, which was enough to free it up and kickstart it - you'll need some torx screwdriver bits - remove the battery cover (it may be a bit sticky since it is wedged against a rubber seal that it may have stuck to, but it does just lift off, there's nothing to snap), remove the black plastic retainer underneath that which hides a couple of screws holding the head assembly (you may need to prise the battery up to get at them) - undo them and you should be able to pull the head assembly off and push the motor up from underneath to free the plate holding the three cogs driving the head - beneath that is a big cog attached directly to the spindle, spin that by hand while starting the razor and it should hopefully spring back into life since you'll have freed the seized spindle.
Posted on Jul 19, 2008
MsCtrl
  • 6 Answers
SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Posted on Apr 16, 2009
SD Tech
  • 14553 Answers
SOURCE: My Philips 60PP9202 has blue wavy lines that comes
Go into the customer menu with the remote and look for "convergence" if the red or blue will not adjust in some direction you have a bad convergence chip. This set uses 2 STK-392-120 chips---both need to be replaced along with any of the 6.8 ohm resistors around them that are bad--a bad resistor will be discolored or white in the middle.
With the back cover off the chips are located on two metal heat sinks on the large board on the left side (as you look from the back) and both will have the STK-392-120 number printed on them in white--the chips are black in color.
Most of the time you just need to replace both chips and adjust the set with the remote control. You can buy both chips for about 13 dollars on Ebay--if you can do this repair yourself you will save a lot of money!
Most shops charge 300-400 for this kind of repair---I do lots of them here for 200-250 including parts, labor and house call. Now is the slow time of year for TV repair shops--shop around--if they say "it has to go to shop" keep looking; any good tech can do this repair in your home and it usually takes about an hour.
I do not know how much skill you have but if you need instructions I will help you. This problem happens for a simple reason--the chips are about 2 inches wide and 1 1/2 inches tall with 18 pins each--the back of each is metal and a white grease is applied to each to transfer heat quickly to the metal that they are bolted to. After some years the grease dries out from the heat and one of the chips cannot move the heat fast enough and it fails.
IF YOU HAVE ANY QUESTIONS OR NEED HELP CONTACT ME BY REPLYING TO THIS POST.
I DO THIS here for free so if this has helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 04, 2009
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Posted on Mar 06, 2010
Philips norelco sensotouch replace the shaving unit. replace damaged razor heads
You will find RQ11 shaving heads at shaveroutlet.com at the link below
http://shaveroutlet.com/philips-norelco-rq11-sensotouch-replacement-heads.html
Mar 01, 2015 | Norelco Health & Beauty
Where can I buy the replacement for the triple head?
Philips norelo RQ12 replacement heads for norelco SensoTouch 3D 1200 series electric razor replacement shaver.
norelco RQ12 replacement heads
Feb 10, 2015 | Norelco SensoTouch 3D 1200 Series Electric...
How to shave your neck with electric shavers
I find going in circles and diagonals against the grain is best.
Aug 16, 2014 | Philips Norelco 8175XL Electric Shaver
Clean
Please see diagrams below for RQ12+ heads on shaver model 1290X
Jun 29, 2014 | Norelco Philips SensoTouch 3D 1290X Shaver...
The norelco shaver i have does not shave
If the shaver is running ok but does not shave well, the blades either need cleaned or replaced.
You will find replacements for 8175XL model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq9-replacement-heads-p-252.html
Scroll down the page for tutorial video showing how to remove blades for cleaning or installation
Oct 07, 2011 | Philips Norelco 8175XL Electric Shaver
Health & Beauty Logo
51 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
