Question about Miscellaneous
It has nothing to do with automotive, it is a Boeing spec. BACD2085N030M is for a threaded hole.
2 Suggested Answers
  • 48235 Answers
SOURCE: boeing spec tap size for bacd2085n030m
you will need to explain what is a bacd2085n030n as that means nothing to anyone but you
is it a screw , a plug a electronic unit or what
post it all again as posts are not linked if you want an answer
Posted on Dec 28, 2016
Do you have information on Boeing spec F-15-.02?
No we do not, what is this spec for?
May 17, 2017 | Cars & Trucks
I would like to view the seat layout for a boeing 777 300er
About 53,900 results (0.65 seconds)
Search Results
SeatGuru Seat Map Emirates Boeing 777-300ER (77W) Three Class V1
For your next Emirates flight, use this seating chart to get the most comfortable seats, legroom, and recline on Boeing 777-300ER (77W) Three Class V1.
Mar 21, 2017 | The Computers & Internet
Boeing spec tap size for bacd2085n030m
Dec 28, 2016 | Cars & Trucks
What are the 2006 suzuki forenza head bolt torque specs?
modern engines do not have a torque setting as such but start at 20 ft lbs and then go to a angular degree setting requiring an angle meter for the studs . IT will be available on line for your engine . Ensure that the stud holes are cleaned out with a thread tap and there is no water or oil at the bottom of the hole . Any threads that go into a water jacket must have thread sealer applied before fitting.
Jul 26, 2014 | 2006 Suzuki Forenza
Looking for the torque specs for a 83 ford F 700 370 V8 rear main cap
v8_15426378.gifCylinder NumberingDistributor Rotationford_cyln_1234.gifv8_dist_ro_ccw.gifRotor Under Cap Spins:
Torque Specs
These specs may not be correct for your application.
Verify your engine specs with a service manual for your year and model.
always torque bolts in three equal increments
Bolts or PartsLube or SealerTorque to:Main CapsEngine Oil105 ft-lbs.Warning!!! If you are using ARP bolts, you MUST use
their specs. Click Here!Connecting Rod Bolts
Engine Oil45 ft-lbs.
Cylinder Heads
Engine oil
(blind hole)
(water jacket)
140 ft-lbs.
Rocker Arms (non-adjustable)Engine Oil20 ft-lbs.Oil PumpEngine Oil25 ft-lbs.Oil PanEngine Oil15 ft-lbs.Cam Bolt (upper gear)Thread Locker45 ft-lbs.Front CoverEngine Oil20 ft-lbs.Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer30 ft-lbs.
Valve CoverEngine Oil10 ft-lbs.Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker85 ft-lbs.Clutch Pressure PlateThread Locker35 ft-lbs.Centerbolt
(Harmonic Damper)
Thread Locker90 ft-lbs.Bellhousing
(Transmission to Block)
Oct 23, 2013 | Cars & Trucks
Torque setting cylinder head bolt
Try posting in the automotive area! You should get somebody there that can help.
Jun 25, 2013 | Honda Horizontal OHV Engine for Non Pumps ...
I need the torque specs for a 96 grand cherakee 4.0 motor
Hello, different size, grade, thread size, application will always have something to do the torque specification of bots, nuts, plug etc.
Remember, to get the proper torque specification on bolts, nuts and threaded holes. If these have been used on an engine and it being repaired/overhauled. To get the proper torque spec these items will be need to cleaned inside and out, threads on bolts need to be straightened, and the same for nuts and bolt holes in the engine block, head, timing cover----all bolts, nuts, threaded casting holes all need to be rework to presence condition... Almost new in shape. Now, once this is done you can get the proper torque requirement and to get these spec. all bolts, nuts, threaded holes need to be oiled first. They the torque can be set properly as to the manufactures specifications. Also, there are not set standards for torquing head bolts on a 265 cu/in Chevy and compared to a Ford 265 cu/in engine, they will be totally different.
If you don't the torque spec. go to your local library they have many American Auto Maintenance Manual that will give the all the information that you need. So, just remember all bolts, nuts, machined holes with thread need to cleaned and resized the threads. To torque any bolt will need to oiled--not much.... I hope this helps you and I wish lot of luck. GB...stewbison
Sep 24, 2011 | Jeep Cherokee Cars & Trucks
What are the threads and pitch for a Mongoose Mtn. bike pedal - Right side?
The make of the bike does not define the crankarm on it which might define the spec of the threaded hole.
A simple web search for "bicycle pedal thread pitch" leads to..
Look for "pedal threading"
Aug 19, 2011 | Cycling
Oil tank threads for drain plug stripped. Unknown why, I was using correct torque specs. May have been overtightened by deaker when I had oil changed. Any solutions to repair threads?
If you live in the USA, you can go to an automotive shop and look for an item called "Thread Saver", it is a coiled soft steel spring that you use to fill the gaps between threads. Mind you this only works on minor thread strips. Any major thread damage will require either a replacement or a welding of a new bolt to the block.
Dec 23, 2010 | 2006 Yamaha Roadliner S
I cross-threaded the plug on my sons ttr 90. whats the least expensive way out of this mess? thanks
Take the plug for size reference and buy a helli?coil kit. Stuff a grease filled rag into the plug hole and drill out the hole to repair spec.Tap it to spec an install repair threads.They will accept a new plug.Carefully remove rag,lots of metal shavings should come to. Blow out the hole real good with air.All set.Get the kit from a machine shop if you can.They can help with any questions about sizes for the drill bits.
Mar 25, 2010 | 2002 Yamaha TT-R 125 L
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
