Question about Samsung Televison & Video
How can I fix a 55in Samsung LED screen that has a faint black cloud in the corner?
I have a 55in Samsung LED that has started showing a faint black cloud in the upper right corner of the screen no matter what is showing. The screen also dims uncontrollably even in steady lighting. Software is up to date. The PIN to reset is not recognized. Picture test is fine except for the cloud.
  • Samsung Master
  • 6,694 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 29, 2016
Have samsung un55c9000zfxa led tv with horizontal lines across screen can it be fixed?
It's either the control board or the display itself.
You'll have to find a TV repair company. They won't be able to tell you for sure until they test it, and they may charge you to test it. The control board should be a cost effective fix, the display won't be.
Unless you're trained in Electronics, don't open up the unit and try to fix it yourself, there are hazardous voltages even when the TV is unplugged!
Jul 18, 2016 | Samsung Electronics UN55C9000 - 55in 9...
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
Samsung tv does not completely turn on
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 05, 2015 | Samsung Electronics UN55EH6000 - 55in...
If my Samsung 55in led tv if off all nite, it will turn on ok in the morning. if I turn off again after its on for an hour or so, it will not turn on again, until many hours off.
Main power supply regulator board fault. Check the start voltage resistors for developed high resistance value. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 24, 2015 | Samsung Electronics UN55EH6000 - 55in...
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
I just bought private sale 55in hisense tv,,,,,,,,,,,only displays half screen,,,,easy fix or costly fix???
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 30, 2014 | Hisense 710 Series 55T710DW 55" LED TV...
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
The TV has a Black cloud on the right half of the
My parents have the same issue with their Sony KDL-46V4100 TV and were told by the tech that the LCD screen was physically broken and would have to be replaced. The replacement of the screen would cost more than a brand new TV and the TV is not longer under warranty. After the TV is on for awhile the Black cloud goes away but it always comes back when they turn the TV off/on. It stays for 20 - 30 minutes sometimes. The Tech took both top corners of the TV and pushed one back and pulled one forward to show them he could recreate the problem after the black blob cleared up. By twisting the corners he made the blob reapper which he claimed was becuase of the damaged screen. I have no idea how the screen was damaged? I helped them take it out fo the box and set it up. We never dropped it bumped it once? It's never falled off the stand so go figure? It would be nice to find more people with this issue and get a recall going. Something that expensive should last longer than to two years.
Jul 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
"clouds" on 32" Samsung tv screen
My best suggestion is to replace the inverter to the lcd panel.I could look up the part number if you need.Let me know - edcarson
Feb 18, 2008 | Samsung TXM3281HF 32" TV
Televison & Video Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
