Question about Coffee Makers & Espresso Machines
Doesn't brew all the water from reservoir - Coffee Makers & Espresso Machines
    Scholar:
  • 78 Answers
This is a wild guess, without knowing the make & model of the coffee maker. The brewer has a timer to stop brewing.
If the size of coffee made is small, one can buy a brewer with larger capacity.
Posted on Dec 30, 2016
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Posted on Jul 11, 2010
heatman101
  • 43501 Answers
SOURCE: only 1/2 cup or less of coffee brewing. Water is
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: My coffee maker states that
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 26, 2011
tcman1169
SOURCE: Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Posted on Dec 26, 2011
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Tip
Keurig Home Brewer instructions for de-scaling with white Vinegar
A. PREPARE
Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup).
Step 2. Empty the water in the water Reservoir.
B. FILL AND CLEAN
Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area.
Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink.
Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on.
C. RINCE
Step 1. Ensure the Water reservoir is filled with fresh water.
Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3. Repeat the brew process until the Water Reservoir is empty.
Step 4. You may need to perform additional brew cycles if you notice any residual taste.
on Aug 10, 2010 | Coffee Makers & Espresso Machines
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Doesn't heat or brew.
Send to Factory for repair.
Oct 19, 2012 | Keurig B30 Mini Coffee Maker
How do you adjust the water level
After the first brew the machine should brew excactly the amount of water added to the water reservoir. Since the reservoir always keep half full then you should add the maximum amount you need in two steps.
Apr 07, 2012 | Grindmaster B-SAP Coffee Maker
1. It sometimes doesn't give me a full cup as per the setting. 2. It was hardly working and I descaled with vinegar - it worked while I cycled the vinegar through but then quit working entirely
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 04, 2011 | Keurig Special Edition B60 Coffee Maker
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
To begin, you will need the following:
  • 48 ounces of undiluted white vinegar
  • Large ceramic mug (do not use a paper cup)
  • Access to an empty sink
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
Keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Jan 25, 2010 | Keurig B60 Coffee Maker
Coffee leaks after it is brewed
The water reservoir on this mdoel is very close to the coffee reservoir - if excess water gets between the wall of the coffeemaker and the coffee reservoir, it will leak exactly as you described. Make sure no water spills out of the water reservoir when your pour it.
-Tha Mp3 doctor
Nov 23, 2008 | Cuisinart DCC-2000
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
