Question about Garden
What is the thread on the bump head model TB575EC
How to remove bump head
The head should have two tabs on either side that you push in at the same time to release the spool.
Jul 17, 2014 | Ryobi Garden
I have ryobi 137r . i cannot ge the head off to replace the string
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,don't forget to give 4 thumbs up,any comments welcome,thank you, ``
Dec 23, 2011 | Ryobi 15" Electric Factory Reconditioned...
I am trying to replace the head on my TB575EC trimmer but can't remove the black inner spool. Any suggestions?
Unscrew the head's center bump-knob counterclockwise with your fingers. Pull the bump knob off and take the spool cover off the head. Slide out the spool and any remaining cutting line. Lift out the spring underneath the spool. Take out the slide washer. Unscrew the arbor bolt either clockwise or counterclockwise, depending on model, in the center of the trimmer head using the wrench. Take the entire head off the end of the shaft.
Sep 03, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do i replace the line in TB575EC trimmer?
Your manual will have diagrams and instructions in detail for restringing. You can use the following link to get it.
Both the model number and the serial number for Troy Bilt Trimmers are 11 characters in length. In your case, 41ADT41C966 is the model number, not TB575EC. You will have to find and provide the 11 character serial number. Input both of these on the following page and a manual is yours.
May 07, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
To remove head to refill line which way do I turn bumper knob?
As a general rule it is right hand threads on curved shaft trimmers and left hand threads on straight shaft trimmers. The major exception is on homelite manufactured units. On Homelite units the black bump knob is right hand and the red bump knob is left hand
Sep 20, 2009 | Garden
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Bump feed on Strimmer head will not un screw. it Just turns constantly
your strimmer head has rounded where the bolt is located.You will need a new head so you have to break the plasic to get at the bolt and fit a new head.
Jul 19, 2009 | Garden
Where can i get a replacement bump feed strimmer head for my Husqvarna strimmer
Lowes, Home Depot, or any small engine repairer that deals in either Oregon or Rotary repair parts. Or try Husqvarna directly:
Jul 10, 2009 | Garden
Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
