Question about The Watches
I have a bucherer chronograph watch with a number 1534 on the of the case. Can you tell me of any history?
5 Suggested Answers
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Posted on Sep 29, 2008
SOURCE: setting a Citizen Chronograph watch
assuming the battery isn't dead (IF IT IS DON'T TAKE THE BACK OFF, YOU WILL LOSE THE SPRING THAT MAKES THE ALARM SOUND) the button on the bottom right click it until the function selector is pointed to time, then pull the button out, then the top two buttons i believe change the hour hands. before setting the time you will need to zero this watch out, or calibrate it or the date will not change in synch with the time at midnight.
my battery is dead and i am a truck driver and am therefore having a difficult time (no pun intended) finding a place i can get parked to have my battery changed. please believe me when i tell you that you will lose this spring, a jeweler lost mine once and it took months to order a new one
Posted on Sep 24, 2009
mcdevito75
  • 1970 Answers
SOURCE: bucherer watch serial number
mcdevito75 here, The serial number will be on the movement itself, the number on the case helps but you need to look at the movement for exact ID of the watch
Posted on Jun 18, 2010
kapishtech
  • 2272 Answers
SOURCE: Have a rotary chronograph watch
On the back of the watch there is a circle shape button like. To change the time, push that button like circle with a pointed object until correct time is shown. Check out.Thanks.
Posted on Jul 26, 2010
I need a case for a bucherer-2671 17jewel watch movement. I believe it is 18mm dia., but don't what cases fit it.
Sorry we do not sell parts. Contact a local jeweler for help with parts.
May 01, 2017 | Watches
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
Bucherer watch serial number
Jun 14, 2010 | Watches
Nautica Chronograph Watch for Men-Instruction to set time & Date
hello
i have hour nautica ... number A29506.. i wants to change date ... please tell me how to chenge .. maybe you write in my e-mail
jusufidrizi@yahoo.com
tthenks..
Oct 19, 2009 | Nautica Blue Dail Yacht Chronograph Watch...
I want to buy a Timex gents chronograph wristwatch immediately with alarm & indiglo.Please tell me various models available in this category so that I can choose one
Timex has a great selection of watches that fit your needs. Timex is Indiglo so all their watches have it. When it comes to chronograph your also looking at a large number of watches. Here is their website to help you narrow it down to more specifics.
http://www.timex.com/gp/node/n/238494011/190-6525554-2651024?ie=UTF8&timexBrand=core
Sep 19, 2009 | Timex Watches
Setting a cartier chronograph watch
  1. click the top button to stop the second hand
  2. click the bottom button to reset the timer
  3. pull the crown out all the way
  4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
  5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
Sep 15, 2009 | Cartier Tank Francaise Chronograph White...
Setting a Citizen Chronograph watch
Apr 10, 2009 | Citizen Watches
How to set a Honora chronograph watch
You have to upload here all details of the watch: model, ref. number. Movement number and good pic would be very helpfull.
Dec 20, 2008 | Chase-Durer Typhon Chronograph White Dial...
10 year old alarm chronograph
good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
Sep 01, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Watches Logo
Top The Watches Experts
John mullen
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
