Question about Microwave Ovens
National geographic 377nc malfunctions
This system does NOT respond to any type of resets etc and does NOT display accurate time or date. they can be set but within a short time they stop displaying anything accurate at all/ I have removed the batteries from the outside sensor and unplugged the unit which it seems to nothing more than a waste of time. Please help with this or the unit has to go back which is going to be very unproductive as I thought it made an great Christmas gift but instead its a nightmare
  • 9098 Answers
SOURCE: GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Posted on Oct 05, 2007
  • 9098 Answers
SOURCE: My display reads -SE-
-SE- error means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
Posted on Aug 02, 2008
SOURCE: kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Posted on Dec 17, 2008
  • 9098 Answers
SOURCE: Microwave stopped heating, evenything else works
Posted on Jan 10, 2009
  • 6 Answers
SOURCE: wiil not heat anything everything else works lights all looks and sounds like it working but nothing gets cooked!!
It might help to know the brand/model of the microwave, but in general, they are alike in some ways. Most have one, two, or three different switches that are part of the door interlock. This is to prevent the microwave from running with the door open (good idea). I recently repaired my 15 year old Panasonic microwave that had a similiar problem. You punched in the time, hit start, it "turned on", rotated, and sounded like it was cooking, but nothing got hot. Here is what I found.
I unplugged the oven and removed the back cover, it is usually all one piece with 6 or so screws. Inside the oven, where the door latch enters the frame, it is probably pushing on a piece that is activate one or more interlock switches. Chances are, that the switch that prevents the "power" components from turning on has failed. Over time these "microswitches" will go bad. I could "jiggle" my handle or push in on it "just right" and get it to work at times, but it needed replacing.
Now comes the part where you need a little electrical knowledge and a multimeter. You will need to check each switch to see if it has continuity when closed and that it opens up, electrically, when open. If you don't know how to do resistance checks or have a meter, ask around, you might be suprised by friends or coworkers that know how to do this. If not, you may be at the point where you will need to take it to a repair shop. If you can check the switches and find one that is bad, they only cost a few bucks, and you will be back in business. Reassembly is pretty easy.
This is the part that gets most folks, because they don't have a meter or know how to use one, a repair shop will probably want $50 - $100 bucks (minimun) and you can buy a new one for twice that. This is one reason our landfills are full of small appliance that still have a lot of life left in them. You can buy a cheap meter at Wally world or radio shack. If you want to give it a shot, follow up to this post, and I will try to walk you through this. Hope this helps.
Posted on May 30, 2009
Display image cannot be deleted and seems to be part of a time-set procedure?
If you wish to get some details about microwave oven repair ; check the site linked here. Pull up older posts.
Sep 13, 2016 | In Microwave Ovens
Oven comes ON when closing the door.
Sounds like the control mechanism has lost control.
Disconnect from Power & try & reset Date / Time Etc
Time for a new Microwave
Dec 02, 2015 | Microwave Ovens
How can I reset contrast so I can see time, etc??
hi Nancy , it may have a internal battery that needs replacing or the display itself is faulty...
Oct 23, 2014 | Dacor DMT2420SS Microwave Oven
Solution-GE spacemakerXL microwave oven model:JVM16505H01
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
Ge eterna series - installed above oven. microwave stops working and display instructs to set time and date, then after setting time and date and starting oven again it stops after a few seconds and asks...
The magnetron draws a lot of power and the mains may be dipping beneath an acceptable level, causing the panel to reset.
Check the supply cable size and any connections.
Jan 23, 2011 | GE Microwave Ovens
wow.......... an exorcism may be in order.......Sadly your microwave circuitry is malfunctioning which is a costly repair. I would seriously consider trashing that possessed unit and purchasing a new one. the new ones are greener too, use quite a bit less electricity
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Buttons not responding on nn-s235
My microwave nn- s235 have the same problem only stop botton waork but no child is displayed in the display
Jun 14, 2009 | Panasonic Microwave Ovens
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
