Question about Refrigerators
What activates the ice maker - Refrigerators
    Problem Solver:
  • 12 Answers
The rotation of the ice paddles during the rotation after the ice is evacuated it triggers the water on during the rotation when the panels are almost back to the home position it cuts the water off it's a timed rotation to fill the ice cups the proper water level
Posted on Dec 29, 2016
How do I run diagnostics on a Frigidaire Gallery Refrigerator
Ice Maker (Flex Tray Fresh Food Compartment)
The Ice Maker must be turned on before entering the
Service Mode. Check the 'ice off' indicator on the User
Interface to verify that the ice maker is in on.
Diagnostic Service Mode Activation
Express-Select ™
To activate the Ice Maker Service Diagnostic Mode,
press and hold fresh food and freezer up (?)
simultaneously for up to ten (10) seconds.
Pro-Select ™
To activate the Ice Maker Service Diagnostic Mode, press
and hold 'options' and 'power on-off' simultaneously for
Activation of Ice Maker Service Diagnostic Mode
automatically turns off all Ice Maker Control PCBA
outputs. The compressor runs at fixed speed of 4500
rpm and the condenser fan turns on until Service Mode
is deactivated. The damper is closed and the fresh food
and freezer lights are enabled as well as the alarm audio.
Defrost of the main system is not allowed.
Express-Select ™
To exit service mode, press and hold fresh food (?) for
up to 10 seconds.
Pro-Select ™
To exit service mode, press and hold the (+) key for up
to 10 seconds.
Service mode is also automatically deactivated after 5
minutes of no key entries (that includes Communication
Lost). All outputs are turned Off. Previously selected
main system and ice maker operational modes are
To actuate an ice maker load of the selected test step
(turn on or off), use 'power on-off' on the user interface.
To step to the next ice maker sequential test, press fresh
food (?) or '+' on the LCD screen. To step back to the
previous ice maker sequential test, press fresh food (?)
or '-' on the LCD screen. The selected test number will
be displayed on the fresh food display.
After pushing 'power on-off' to start automatic test
or turn on the load, the ice maker control will display
the test result on the freezer two digit display. When
waiting for the test to be automatically performed and
the result displayed, the test number (test ID) will flash
on/off. After the automatic test is completed the test
result will be displayed as "P" - pass, or "F" - Fail.
For an interactive test, the technician manually activates
the load using 'power on-off' and physically verifies the
system response. Pressing 'power on-off' again turns
the load off. The freezer display shows the current or
expected state of the load. During the load transition
the fresh food display flashes the test ID. After the last
test step in the ice maker test sequence is completed,
the next advancing action will scroll back around to the
first ice maker test. Stepping back from the first test, will
scroll the test sequence backwards to the last test in the
Note: The only test that the test number will flash during
the test is the bail arm test.
Note: If you advance to another test before the present
test is completed the ice maker will continue to run until
the tray reaches the home position before the next test
will start.
Service Diagnostic Mode Test
Test 52C: Ice maker Thermistor Test.
The current Thermistor temperature is displayed on
Freezer display when the test is started. It will show the
temperature at the ice maker if the thermistor is good.
A "OP" will be displayed for open and "SH" for in short
circuit condition of the ice maker thermistor.
Test 55C: Water Valve Test
NOTE: Prior to initiating this test, verify that the ice tray
is empty. If not, empty the ice tray to prevent water
from overflowing into the ice bucket. To empty the ice
tray, remove the ice bin, place catch pan under the ice
tray and initiate test 63C. The tray will twist and empty.
Touch 'power on-off' to start the test. The lower control
board will turn on the green and brown water solenoid
valves for a duration of 4.6 seconds if set for small cubes,
5.8 seconds if set for medium cubes or 7.0 seconds if set
for large cubes. Additional 'power on-off' activations are
ignored. If you want to re-run the test you will need to
advance to another test and then go back after you drain
the water out of th
Jan 16, 2017 | Refrigerators
Why is water not going to ice maker
Check the hose to the ice maker and make sure its not plugged and then check the switch from the ice maker to make sure power is activating the solenoid that turns on the water. If solenoid is good then your ice marker is bad
Jan 04, 2015 | Kenmore Refrigerators
Automatic ice maker stopped working, Checked water supply to back of freezer, and the water supply is on. Arm on ice maker seems to be in correct position. there is no water in ice maker. can feel the...
Assuming you have active water supply to unit, either water valve or ice maker is bad. If Ice Maker is sending power to valve during Ice cycle, then valve is bad. If no power to valve during Ice cycle, then ice maker is bad.
Sep 11, 2017 | Amana ARB2557CSR / ARB2557CSL Bottom...
No water to the ice maker
Check that the pipe that fills the ice maker is not iced up. Also check that the solenoid on the back (where the waterline hooks up) is making a humming noise when the ice maker calls for water.
Apr 30, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Ice maker not working. Water is going to fridge,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Dec 15, 2009 | Fisher and Paykel Active Smart E522B...
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water in ice maker
check water supply
check water valve
check for frozen water tank
check if the ice maker is calling for water by cycling the ice maker (remove cover, put jumper wire between holes marked T and H close door switch and let ice maker advance till it clicks, remove jumper wire, close door and give it several minutes to activate water valve, if it never does you need a new ice maker.
Jul 14, 2009 | Refrigerators
Ice maker won't work
Check your wiring to the timer motor. UNPLUG IT
Take off the cover look for any loose wiring. If all the wiring is in place you may have a bad timer motor.
Jun 28, 2009 | Samsung RS2630WW Side by Side Refrigerator
Make sure you check your water supply and filter if you have one. Check the ice maker. Make sure the motor and gears are turning in the ice maker itself. As the ice maker goes through the cyle it activates the water solenoid for about 5-10 seconds at a certain piont to fill it. If the ice maker isn't running the ice maker will not fill.
Apr 20, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
