Question about Garden
Ignition module for FS76 trimmer - Garden
Stihl FS76 ignition module
41334001301 coil, NLA
you might try an obsolete part retailer
Ron's Saw Shop
1-800-433-6304
South Dakota
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 28, 2016 | Stihl Garden
How to refill the chord on a F576
Hi, your model is an FS76, Could you please add a picture of your cutting attachment and I will try and help you.
Dec 08, 2015 | Stihl FS 85 Weed Eater
Repair stihl 45c
Check spark plug is functioning. (replace if unsure)
Check on off switch and wiring from switch to ignition module.
Check ignition module is functioning. (remove earth wire from ignition module, this should make sure the ignition module sends current to the spark plug and not to ground)
Check spacing between flywheel and ignition module. 0.25 filer guage.
Jun 22, 2013 | Stihl Garden
Leaking fuel tank stihl fs76
no seals just the tube seals itself to the hole in the tank for it
Aug 24, 2012 | Garden
How to load cable
If its the 'autofeed head' all you do is squeeze the two sodes of the strimmer head where the 2 ciucular recesses are and the outer ring should just pop off exposing the bumper cap and inner spool.
Aug 17, 2012 | Stihl Fs76 Line Trimmer Intake
What are the high and low carb settings on a stihl fs76?
high 2 turns out and low 1 and 1/2 turns out
after you get runing up operrating temp ajust
again throttle wide open ajust high neadle and
win idle ajust low neadle
Jul 18, 2009 | Oregon Scientific Complete Carburetor for...
I have a stihl fs76 weed trimmer. It will start but not stay running. I took the carb apart cleaned it. It looks fine but it still won`t run good. Any common problems or ideas ?
Hi..my name is Keith...it sounds like the reeds in your carb needs replacing...usually if you use a carberator cleaner on them..it will ruin them..plus age will make them stiff..they should be as soft a rose petal..and its cheap and inexpensive to replace..but you have to pay attention to how many layers and the shape of the reeds that come out..because the kit that you buy will fix several different carbs..i hope this has helped..if not..write back
Jul 01, 2009 | Garden
What should gap be between ignition module and flywheel magnets on troybilt 575ss 4 cycle weed trimmer? It is a year 2006 model.
Pull the module back, tighten it up and align magnets on flywheel with module. Put a business car between them and loosen the module. It will move against card. Tighten the screws there. It's set.
Jun 27, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
