How do I change the bulb in my heater
The model number is DFI 8511-02
Change bulb in heater controls
you need to remove center dash assembly to unscrew the heater control assembly once you pull out the heater control assembly you should have access to the rear where the tiny bulb is and you will need the number marked on it or in your owners manual in specs lights some auto parts dont have the same size since there are many models and sizes you might have to buy from dealer and they have to order so look around to find one
Aug 05, 2014 | 2004 Peugeot 206 SW
My Candy DFI Plan shows E3 and stops washing after 10-15 minutes. The problems started because electronics( I swithed with new) than I change the water pump, the heater, the thermostats and when is on,...
E3 - Water heating time out or fault
The dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element.
Check water heating element wiring
Check wiring to main control module
Dado
Jul 28, 2014 | Candy DFI Plan Built-In Dishwasher
E3 - Missing heating of the water.
Could be:
· Clogged filtering plate.
· Defective heating element.
· Defective wiring (open circuit, leads
off place or loose).
· Defective electronic control board.
You have already changed all major electrical components energized during the heating phase. But do not forget that failures sometimes could be mechanical. For example: failure could be in hydraulic circuit of pressure switch, sometimes hydraulic circuit can lost air pressure. Another note would be that your dishwasher have NTC thermistor which every second gives information about temperature to electronic than electronic controlled heating element by a relay.
In order to heating element come under the voltage is necessary to fulfill a couple of requirements. Microswitch on the door in the closed position, the pressure switch in position 11-13 (full position , level of water) and the main switch is turned on.
24881895-svalokc2bmago0zdlfvpjh25-3-2.png Dado
Motor running but no flicker effect shaft drive
If you check your owners manual it should tell you how to change bulbs etc. Are you not seeing light, or light comes on but no flicker? If you can reply with model number on your unit, perhaps we can guide you to diagnosis and repair easier.
Sep 21, 2011 | Dimplex Compact Electric Flame Stove...
Flame quit...do not see any bulb.can this be replaced? Thank-you
Sue, if you're referring to an Electric Fireplace Heater or Electric Wood Stove look heater, yes you can replace the bulbs. But, I would need to know who the manufacturer is and the model number.
Rich
Mar 21, 2011 | Heating & Cooling
Change bulb on dimplex fire not sure of make and model
If it's a fireplace that sets inside a free standing cabinet mantle, you access the bulbs by removing the glass on the front (actually, it''s plexiglass). Then remove the logs and the glowing ember bed (It lifts out). Now you can see and have access to the bulbs to change them.
It it's wood stove look-a-like unit, you can access the bulbs by removing the rectangular panel on the back, near the bottom of the of the unit. Removal of that panel gives you access to the bulbs.
Hope this helps to answer your question.
Mar 12, 2011 | Dimplex DS5598 Mid-Size Heater
How to or were you change the bulbs, diagram if possible
Dimplex has the Owners Manual for download in a pdf format on their home page website. You will need to look for the Owners Manual that matches the Model Number you have.
Jan 31, 2011 | Dimplex DFI2309 Electric MidSize Heater
LYM 28 E how do you change a bulb? james.g4nps@ntlworld.com
I can't imagine that this wouldbe too hard. But I haven't had experiance with this model. Check for any removeable doors or parts that will allow you to get to the inside of the heater. Make sure it is unplugged before doing anything!
Either go to: www.dimplex.com or call their number: 1-800-668-6663 ext : 358 They are very helpful! They can help you ...
Nov 15, 2010 | Dimplex Compact Electric Flame Stove...
Dfi km400 mlv support drivers
Check following link:
http://us.dfi.com.tw/Product/xx_product_spec_details_r_us.jsp?PRODUCT_ID=1960&CATEGORY_TYPE=MB&SITE=US
One more frindly advise. Try using google. You get the search results fast from there..
Jul 28, 2008 | DFI KM400-MLV Motherboard
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
