Question about Onkyo Audio Players & Recorders
I have no sound on right side of Onkyo TR-SR503. I'm trying to get to fuses under speaker circuit board, but don't know how to take the gray flat cables out of holders? Clamped in after holder is off.
    Habit-Forming:
  • 195 Answers
The little clip pulls up and then you can remove the cable. Be careful as they can break. You may also like to note that there is usually a reason why a fuse goes, and this could either be that you touched the speaker wires together, your speaker is faulty, or the output transistors have blown on that channel.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Posted on Jan 06, 2017
Onkyo AV- SR503 WHY DOES IT MAKE CLICK SOUND WHEN I PRESS POWER BUTTON. THEN IT CLICK AGAIN AND TURNS OFF
There are a couple of possbilities here:
1. Make sure you have a good power connection that is not overloaded. If you are using a surge protector, try plugging the amp right into the wall to see if that makes a difference.
2. check all your speaker connections to make sure you do not have a short. The amp may be shutting down to prevent damage.
3. If you cannot find a problem there, what you may want to do is disconnect all speakers and try to turn the unit on. If it starts normally then you know for sure you have a speaker problem.
4 If above does not resolve problem, then unplug all inputs and try turning it on.
If it still does not come on then likey you have a hard fault with the amp and it will require service.
Jun 05, 2015 | Onkyo Audio Players & Recorders
SAMSUNG SP-50L7HX DEAD FUSE BLOWN BLACK OBVIOUS SHORT CIRCUIT ANYONE KNOW ANYTHING IF BOARD REPAIRABLE O
Try shopjimmy.com who carries almost all the Samsung boards--if fuse right where power cord does come in trouble is right there.
Aug 30, 2012 | Samsung Televison & Video
Onkyo tx sr502, sounds coming from all speakers except sub. in test sub works
hi,
Try the following setup to activate the sub
1.Press the [AMP] button on the remote and then press [SETUP] button.
2. Use the Up and Down arrow buttons to select "1. SP Config," and then press the [ENTER] button.
3. use up and down arrow to select subwoofer setting.
3. While the subwoofer setting is selected, use the Left and Right arrow buttons to select Yes .
you will surly get the audio from the subwoofer.
ok
Feb 19, 2011 | Onkyo TX-SR503 Receiver
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
I have the Onkyo HT-S5100, the 5 speaker are set
also, you might have to search through the menu of the receiver, and set the surround back speakers to be zone 2 instead of using the 7.1 configuration that is probably default.
i think zone 2 will only play sources that are hooked up with analog connects, ie. red/white cables. try using the radio to see if it works. you might have to hook up your cable/sat box, cd player, dvd player, whatever you have that you want to listen to with both digital and analog cables to get everything to work right.
Jun 12, 2009 | Onkyo TX-SR503 Receiver
Blow right speaker channel - ONKYO TX-SR506
There is some way to change a protection (fuse?). No. The fuse usually was not broken. How long did your amp turn on?
3 seconds (DC protect) OR immediately shut down (Over Current protect)? How to confirm?
1.Unplug the amp.
2.Remove the metal cover.
3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
4.Remove this long vertically installed board mounted by 2 screws.
5.With 2 screws removed, just pulling this board out and hold it with one hand.
6.Plug the amp and switch it on.
7.If your amp stays ON forever, the problem is from this long board.
8.If switch off at once, the problem is from power amp board.
Try the above- mentioned steps. I will tell you what to do next. Just search you tube for SR600 cap replacement. I have written an email here. Write an email to me if you want to fix this amp.
Sep 30, 2017 | Onkyo HT-SR800 System
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Onkyo receiver problems
All speakers and lines OK?  Sorry for basic approach!!  Protection is supposed to work when speaker outputs are loaded under recommended Z. speaker Z is a setting too ... along with several other paramenters.  Also, re the "last return" ...  Maybe the back surround speakers were turned off in settings?  Again, apologies if you've tried all this basic stuff.  I've just bought one of these amps and have probs with the FM tuner not tuning anything.  Mmmm. Back to the shop??   Cheers, Chris
Oct 03, 2007 | Onkyo TX-SR503 Receiver
Onkyo TX-SR504 - Sound problem
Ooops, that did not work.  OK try  http://www.retrevo.com/s/Onkyo-TX-SR503-Receivers-review-manual/id/365ag216/t/1-2/  for download of manual in .pdf form, and English too!   Hope this helps.  Cheers,   Chris  :)
May 05, 2007 | Onkyo TX-SR503 Receiver
Treble and bass function
In looking through the service manual for this model, I see a Tone Switch that allows you to bypass the tone circuits, and it may be the one all the way to the left of your front panel. If that's not it, I would get out the owners manual and see what they suggest. I doubt that you actually have an electronic malfunction with your unit.
Jan 18, 2007 | Onkyo TX-SR503 Receiver
81 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
