Where can I find replacement circuit board for TCL tv circuit board Model number l40s4690e
  • 9 Answers
SOURCE: Looking for replacement circuit board for HP TV
On ebay for less than $100
Posted on May 23, 2009
spr1949
  • 1182 Answers
SOURCE: 8 solder ic number for tcl falt tv
Can you please check for any jammed buttons on the remote and/or control panel? Try switching on the TV manually, while removing the batteries from the remote. If you notice same problem, the area to be looked into is around the system control area: like dry solder, leaky/dry capacitors and this should be done only by a qualified service technician.
Posted on Aug 26, 2012
gopakumarg43
  • 74482 Answers
SOURCE: want to know the inner kit details of tcl tv model
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 28, 2013
  • 144 Answers
SOURCE: I have a sylvania 32in replacement tv circuit board model srt2232s It doesn't turn on anymore , fuse is good , buzzing coming from a transistor I think any thoughts . Thanks
Hi there, sorry to hear. That "buzzing" you hear is most likely that power supply onboard, pulsing in a failure mode such as a current limit situation. Check for shorted rectifiers, and the common bad capacitors.
Posted on Jan 21, 2015
gopakumarg43
  • 74482 Answers
SOURCE: what is the flyback number of TCL model 2927u?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line output section circuit to many popular brand TVs are given. You can get details by it.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Posted on Feb 02, 2015
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 30, 2017 | Televison & Video
Pls help my tcl tv model tcl 2175u with picture but no sounds.. the speaker is good...
If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jun 12, 2016 | Televison & Video
TCL model L40S4690E. Why does TCL logo appear on screen and nothing else happens?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 30, 2016 | Televison & Video
My tv turn on and stuck on the dark screen with tcl
Nov 29, 2015 | Televison & Video
TCL TV Model L40P60UF; no picture and sound when switched on but stanby led is on. When power on is pressed from the remote control, the red led disappear. What could be the problem
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 08, 2015 | Televison & Video
How i repair my tv model le40fhde3000 TCL do not turn on?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Oct 04, 2014 | TCL LE40FHDE3000 40" 1080p LED-LCD TV -...
Tcl tv not work led is red
What is the model number to your TCL TV. Its SDA-SCL data line should be checked. Check all the output voltages come out from its SMPS power supply section, and make sure all of it are correct. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. In fact, its main board's system control section circuit should be troubleshooted. Check and replace the main crystal oscillator too.
Nov 08, 2013 | Televison & Video
Tcl 21m62s, i accidentally locke the fppa or fpa at the option menu. so now i can't use my tv. what should i do?
The unlock procedure to TCL differs set to set. Even though the model number is one, the circuit board [mother board] used inside will be different, and is actually a Chinese brand. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Unlock procedure to some popular brand sets are given in detail.
Nov 04, 2013 | Televison & Video
My tv is a tcl brand model tcl-14175 i accidentally on the child locked.can I have the child lock code for my tv?please
my tv is tcl model ( t1436a ) , lost my tv's remote controller , please give the model number of remote controller
Sep 24, 2009 | Tvone TV-207 Television
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Jun 15, 2008 | LG 30FS1D TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
