I code SE in my control panel and I have follow all step from the manual but it is not disappear.do you believe I need buy e new control board?
SOURCE: i need a new remote control for hisense tv flat panel, where can i buy one?
I've had very good with the Radio Shack Universal Remote. It recognized everything I had. Try that, because if it doesn't work, you can take it back for a refund.
Posted on May 07, 2008
  • 3 Answers
SOURCE: Washer has error code E47
I have the same problem with the E47 code. I had the service guy over and he brought a troubleshooting sheet. Basically, you must remove the door switch assembly and check the PTC (the white plug on the door switch assembly). According to the diagnostics sheet, if the switch is open or locked, then it is a doorswitch problem, but if the reading on the switch is ~ 1500 ohms, then its the control panel.
The reading on my PTC was ~ 1400 Ohms (which is close to 1500) so I ordered a new control board. I'll post again when it's re-installed.
Posted on Jan 14, 2009
  • 523 Answers
SOURCE: controls not working, but panel is
touch pad
Posted on Jun 01, 2010
jsrock516
  • 5911 Answers
SOURCE: I have a whirlpool double
The following link explains step-by-step how to replace the control panel on most kitchen ranges:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
You can also refer to searspartsdirect.com, pcappliancerepair.com, or appliancepartspros.com for helpful exploded view parts illustrations that will assist you with any repairs you may need to perform.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Nov 03, 2010
  • 10 Answers
SOURCE: My pool repair guy says
BE CAREFUL! MANY ON LINE DEALERS CAN SEND DEFECTIVE OR REBUILT BOARDS OUT TO CONSUMERS. ONCE YOU PAY THEM ITS TOO LATE,
ANYTHING ELECTRONIC, YOU SHOULD ALWAYS BUY FROM A LOCAL POOL GUY YOU CAN TRUST.
Posted on Jan 01, 2011
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
Mar 03, 2015 | Kenmore Microwave Ovens
After a power outage my Samsung SRS580DHLS is displaying and flashing SE? What does this code mean and how do I fix it? Rirht now the control panel only displays SE and does not respond to any presses
Your control board is reacting to a surge in power. Unplug the unit for 5 minutes then replug and follow normal starting procedures. If that does not work think about buying a new unit.
Oct 11, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
The display is showing the letters SE. What does this mean?
Unless there is moisture or grease on the control circuit board, "SE" error means you have a shorted membrane keypad.
The solution is actually a pretty simple DIY job - to replace the control panel frame assembly - which comes with a new keypad already installed.
If I had your full model number from the tag on the oven I could likely give you step by step instructions with the part number you need.
You can find links to helpful exploded view diagrams and part ordering help here, where you can also e-mail me directly.
I recommend that you bookmark that link to your favorites.
Nov 29, 2013 | Tappan Microwave Ovens
My Jandy rs control panel 7751 has gone out?
Yes! Although you the lighting is part of the circuit board, you can order a NEW Circuit Board and install it yourself! Shop around I believe we paid about $375 about a year ago.
The new circuit board should come already pre-wired with a connection plug. Disconnect power to the unit at the breaker. Gently pry off the cover to expose the old circuit board and plug. Gently wiggle the old plug off and attach the new board. I believe there are a couple of screws holding the board in place. The new board should come with instructions as well. If you are at all handy.... save yourself the install fee from the pool tech!
Mar 24, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My new Whirlpool Cabrio stops repeatedly with the UL flashing it never finishes a wash load, do you have a step by step CD explaining the use of this washer? I am about to return it to the store and get a...
I believe this model has a defective control board under the control panel. The new control board has longer times between the drain and the spin. Eliminating the unbalance when it tries to spin with water still left in it. Also check for slow drain this will enhance the problem. The control board is a warrany repair if covered.
Mar 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
SE M600i cant booting
download xs++3.1
download gdfs from http://www.persian-forums.com/f78/m600i-soft-version-overwrite-xs-214/
moz-screenshot.jpguse it to run script on xs
this downgrades your phones firmware
use seus
you got it dudes and dudelettes
mlush from kenya...enjoy btw uiq till i die
Sep 30, 2008 | Sony Ericsson M600i Cellular Phone
Error mesage
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
IF these steps do not work you will have to replace the fuser or fuser heat rod then perform the reset.
May 15, 2008 | Xerox WorkCentre Pro 16fx Laser Printer
Trouble code
  7. Make a copy, to check that the machine is working properly.
May 06, 2008 | Sharp AR-160 Copier
SHARP AR-M277
this should resolve it.
Jan 22, 2008 | Sharp AL-1655CS Laser Printer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
