Question about Building Materials
How do I replace the yellow sensor receiver with the Universal CR-2149 receiver for a moore o mattic xx133 garage door opener?
Diamond E
  • 57 Answers
SOURCE: programming garage door opener
http://www.aaaremotes.com/linearx.html http://www.chamberlain-diy.com/pdfdocs/114A2504.pdf 1rst is to purchase the second is a manual index.
Posted on Sep 13, 2007
  • 3197 Answers
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Posted on Apr 30, 2009
  • 3197 Answers
SOURCE: One of my garage door sensors is yellow while the other is green.
It means your sensors are properly aligned. Are you having a problem?
Posted on Jun 16, 2009
  • 3197 Answers
SOURCE: liftmaster formula 1 garage door opener keeps "bouncing" open
If the door reverses when it hits the floor it is traveling too far. Locate the 'down limit' control on the side of the motor unit and turn this in the opposite direction of the arrow printed on the cover. Some tweaking will most likely be necessary. You can always recognize a sensor problem because the main light will flash 10 times. If the main light isn't flashing it isn't a sensor problem.
Posted on Sep 28, 2009
swolfinor
  • 504 Answers
SOURCE: 2006 GMC Envoy Denali, Universal Garage door
GOTO HOMELINK.COM TO DOWNLOAD INSTRUCTIONS FOR THIS SYSTEM
YOU WILL NEED TO RE PROGRAM THE UNIT WITH YOUR DOOR OPENER.
HOPE THIS HELPS
Posted on Feb 10, 2011
I have a Sears craftsman model 139.53637SRT garage door opener. My remote has not worked in a long time. I use the wall control button and have to hold the button in order to open or close the garage door....
It sounds like your door sensors may be bad or misaligned. Make sure the small light on each sensor is lit and not flickering. That could be the cause of your having to hold the wall button down until the door is closed. You can buy a universal remote but if you only had one remote before it could be the receiver that has quit. A new remote would not fix that but the only way to find out is to try.
Aug 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need the receiver and garage door control button for a NuTone Garage Door Opener Model GB575, GB580 & GB580-8
I think you will need to check into a Sears Model #00953751000 or Chamberlain Model #R39663 universal remote control replacement kit.
Apr 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
Klik2u purchased. Have Challenger Door opener with Multicode box attached (circa 1995). No dip-switches. Has yellow "learn" button, but no matter which code I enter, it does not "learn" anything. Maybe...
UNLESS THE KIK2U HAS A UNIVERSAL RECEIVER IT PROBABLY WON'T WORK WITH CHALLENGER - VERY FEW UNIVERSAL SYSTEMS DO.
GET A CHAMBERLAIN / LIFTMASTER / CRAFTSMAN UNIVERSAL SYSTEM THEY HAVE A RECEIVER AND REMOTE / KEYLESS THAT WILL WORK WITH THE VISOR SYSTEMS IN CARS AND IS VERY EASY TO USE AND RELIABLE.
HOPE THIS HELPS
Nov 29, 2009 | Universal Garage Wireless Keyless Entry...
Garage door sensor light on one is green the other yellow. When they are lined up one stays yellow and one is green. When I point the yellow sensor away from the other one the green goes off. Do you think...
They are doing what they are designed to do. To work properly they must be pointed at one another and to tell when they are aligned the light on the receiving unit turns on.
Jun 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
6 month old garage door will work.
On the back of the opener near where all those white wires go you will find 2 controls. One is labeled "up force." Increase this about 1/4 turn.
May 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Program 2004 mercury mountainer garage opener
Verify the hand-held transmitter is operative.
Prepare for programming the universal transmitter by erasing all three channels (hold down the two outside buttons until the red light begins to flash [20-30 seconds]). Release both buttons.
Select one of the three universal transmitter channels to be programmed by pressing the desired button
Hold the end of the hand-held transmitter 25-51 mm (1-2 in) from the front surface of the universal transmitter so that the red light can still be seen
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
Hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
If the hand-held transmitter appears to program the universal transmitter but does not open the garage door, the garage door opener may have a code protected or rolling code feature.
To operate, simply press the appropriate button on the universal transmitter. The red light is on while the signal is being transmitted.
IF THE GARAGE OPENER HAS ROLLING CODES---
program as above then------
Train the garage door opener receiver to recognize the universal transmitter.
Remove the cover panel from the garage door opener receiver.
Locate the training button on the garage door opener receiver. Location and color of the button may vary by garage door opener manufacturer. Refer to the garage door opener instruction manual or owner literature.
Press the training button on the garage door opener receiver for 1-2 seconds.
Press the programmed universal transmitter button for as long as the universal transmitter red light flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
The garage door opener should recognize the universal transmitter.
Apr 01, 2009 | 2004 Mercury Mountaineer
Garage door opener
Check the electric eyes. If they don't see each other the door thinks there's something in the way. Blinking light is a safety alert to check the travel path.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
49 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
