Question about Minolta - DI200F Printer
I have a minolta DI200 copier. I turned it on today and the display showed 3 copiers. it is flashing the code ox00110007 skid ox 0000620c sp ox 9010fed88. Any one have an idea what could be wrong?
  • Minolta Master
  • 6,321 Answers
That is a abort code. Legacy machine might need a new main board
Posted on Mar 12, 2017
Nitrotrike
  • 589 Answers
SOURCE: minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Posted on Feb 10, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Minolta Di 3010 Error code C0910
Sorry it took so long but I found it.
C0910 indicates that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there is any jammed paper in there.
Posted on Sep 06, 2008
  • 990 Answers
SOURCE: Minolta Di550 error code C-0500
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
goalie39
  • 469 Answers
SOURCE: error code c0200 minolta ep4050
C0200, charge corona failure.
The high voltage wire used to charge the photo-conductive drum is broken or shorted.
It will need to be repaired or replaced.
It is usually a fairly simple job, but you may need the replacement wires to complete the job.
It could be someone has pressed the scoritron grid tensioner and allowed the grid to drop onto the drum.
Great care must be taken when working around the drum area.
If you open the front of the machine.
drop down the transfer section (yellow or green handle)
flip out the toner bottle.
you should see to recessed screws, one behind the toner bottle, one on the far right side of the unit. loosen these all the way,
there may be a plug in each side to disconnect.
you should now be able to slide the unit out.
set it down in some paper, the corona will be the long metal housing stretching front to back on the drum unit.
Remove it by sliding it one way, then it should open like a hinge, open it all the way and it should pop loose of the main unit.
The corona wire is behind the grid, it is the thickness of a human hair. If it is broken you will need a replacement, if the grid was off when you opened the unit up reinstall the grid and reassemble.
If the corona shell or the scoritron is discolored, clean them with a glass cleaner and soft cloth.
Keep the drum covered with paper so it is not exposed to direct light for any great length of time, do not allow the drum to be exposed to direct sunlight.
Hope this is of some help.
Ed
Posted on Apr 19, 2009
Bizhub C350 - C-0510 error code how fix copier
Turn OFF the copier.
Press and keep pressed the Uitlity key and turn ON the copier.
Keep pressed the Utility key when will Trouble reset message displayed.
Release the Utility key,touch the message and turn OFF the copier.
Wait 1 minutes and turn ON.
Apr 12, 2013 | Konica Minolta DiALTA Di200 Copier
Malfunction code C0040
Minolta copier show error code c0040. Please show me the picture that point of problem. The second problem. What is the way we could what kind of minolta di ...in the machine?thanks in advanced.
Apr 12, 2012 | Konica Minolta DiALTA Di200 Copier
Error cod sc32-04
There is no SC3204 or C3204 code on the Minolta Di200. I would either need the correct code or the correct model of Minolta you have. Please provide better information so I may assist you further.
Thank You for using Fixya.
Oct 28, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
Code C0510 on our Konika Minolta Di 181
Check heater lamp or thermostat might burn out
Mar 04, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Di251 error code
most popular solution is you resigin your job hahahah
Jul 11, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta - DI200F Printer Logo
27 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
