Question about Refrigerators
Water is working fine,just want freeze - Refrigerators
Hot water in kitchen only froze
good idea to let the cold water to run a bit to stop freezing up . Pity that you didn't do the same with the hot water. There is only hot water in the tank but the water in the hot water pipes will freeze as the heat goes out of the pipes. (Always to have to wait for the hot water to come through when you use the shower or bath.) The water will freeze up right back to the hot water tank
Jan 29, 2014 | Cars & Trucks
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Why does water dispenser stop working? Seems to work fine after thawing freezer for about a day and seems to freeze up. Water line for dispenser routes through the door.
The water is door spigot can be freezing up if the ice door is stuck open. When you actuate your ice in door function you hear a solenoid CLICK. That solenoid is supposed to open the ice door flapper. If the flapper is not funtioning correctly (stuck open) then in as few as as 2 - 3 days your water in door can freeze again. If you want unit specific information we need your make and model number to better help you.
Thanks for hoosing FixYa,
Kelly
Feb 22, 2011 | GE Refrigerators
Hi can you help ,my fridge is freezing everthing inside it ,it is not overloaded with food ,filter is fine , also water dispenser has just stopped working wondering if water pipe is also freezing ?...
Your thermostat is defective.... and yes, the water may freeze if the internal temp is too cold.
Try unplugging for 24 hours to thaw thermostat and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | Whirlpool Refrigerators
Why does it keep freezing up? The hot side works and the fridge compartment is fine
there is a small fan on the cooler side that may not be working. if this is the case, it will freeze everytime
Nov 27, 2009 | Hamilton Beach Water Cooler with Storage...
My side by side samsung RS2530 bbpfreezer is not freezing any ice
Are you taking too much ice in too short time? The freezer needs some time to freeze the water to form cubes. Another reason is that the water supply line may be blocked by air bubbles. Ensure that the water supply is adequate.
Aug 07, 2009 | Samsung RS265LABP Side by Side...
Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Jan 01, 2008 | Soleus MW-55
Water dispensor is not working, ice dispensor is work fine
It depends on where it is freezing. Can you determine where the freezing is? These things don't usually clog. They can develop what is called a vapor lock in the water dispenser behind the meat drawer in the refer. For freezing let me know where it is freezing.
Nov 18, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
