Question about Refrigerators
The water is working filling the tray but it is not freezing
mikedurland
  • 481 Answers
SOURCE: my ge icemaker will not
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 12, 2008
Maytag317
  • 1136 Answers
SOURCE: Ice maker water line freezes
Hi, it sounds like the water valve is leaking just enough to cause the water to freeze in the inlet tube. This is the most common fix.
If I can assist you further, please let me know.
Thanks
Vic
Posted on May 15, 2009
  • 358 Answers
SOURCE: My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Posted on Jul 14, 2009
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
Posted on May 22, 2010
Ice maker won't make ice
most times I see the tray and fill tube ice up its due to a leaky fill valve , this valve should close tight after filling tray , but sometimes they leak just slightly then everything freezes up in a block of ice
fill valves on most all units is located in back lower left corner , just follow the water line in the back of unit
Jan 15, 2016 | True Refrigerators
How do I stop my ice maker water filler hose from freezing - which stops water from filling the tray?
This problem is caused by a defective water control valve that does not stop leaking water like a dripping faucet. This causes water to freeze in the water fill tube thus blocking fill of ice tray. Replace water control valve.
Appliance 911 Sea Breeze
Sep 19, 2015 | LG Refrigerators
Icemaker arm that sweeps ice from freezing tray hangs up on an ice cube at the end where the water inlet cup is located. Arm cannot continue to sweep ice out of freezing tray.
It sounds like the "freezing" tray may be over filling. If this is the case, replacing the water fill solenoid valve may fix the problem. Another possibility is the ice maker is not seated in its mounting screws properly and the water level is higher at one end than the other.
Oct 03, 2014 | Refrigerators
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
I have a kitchen aid refrigerator KSRG22FTSS01 that the icemaker continues to freeze up in the delivery tube, any suggestions why
This is the fill Tube to the Ice maker tray. It is freezing because the water valve is leaking a little even when it should be closed. This leak is now freezing your fill tube. If you defrost the tube it will work untill it freezes again. The only solution is to replace the water valve. The valve part number for your machine is 4389178
Jan 14, 2010 | Refrigerators
Jul 14, 2009 | Refrigerators
Ice maker tray does not fill with water
replace the duel inlet water valve on the bottom back of frig.,one side has failed-mike
May 22, 2009 | Kenmore Refrigerators
ICE DISPENSER
Dmuehr,
Are you sure it is a leak. Is the solenoid actually cutting off BEFORE the tray is full of water? If not, it is not a leak. The filling time for the icemaker water tray (where the ice freezes) varies depending on the local water pressure. With higher pressure, the tray may overfill. Your icemaker motor module timer may be set too long for your specific water pressure, so that the tray overfills. There is an adjustment on the module for shorter or longer fill time. You will need to remove the icemaker (3 screws probably) and reset the timer. It may take 2 or 3 tries to get it so the trays are about 80 to 90% full.
Jan 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice cube tray not releasing cubes
The ice maker system is pretty simple.. A motor rotates with a gear reduction system and as it rotates... a switch is tripped when the motor reaches a certain point on its rotation... that switch lets water in for a prescribed period of time ( normally that is adjustable) and then as the motor rotates some more.. the ice tray has had adequate time for that ice to freeze and is positioned for it to be released,..at that time.. a small heating element is energized to release those ice cubes and the cubes fall from the tray into the bucket.. Chances are your heater is not working, unplugged or defective.. I would start by thawing everything out and getting the system free of any and all ice.. If after you've cleaned it all up.. and it still fails to release ice..you could be over-filling your tray and that freezes .. which in turn causes the system to fail too..You may need to adjust the fill level by throttle back on the water or if your system has a fill level control.. adjust that.. but first things first.. get the system back to a known good state.. ( meaning free from all ice ) so that you can monitor its performance,. Hope that helps...
Aug 16, 2008 | Samsung RS2578BB Side by Side Refrigerator
Water freezes before getting to ice tray
sounds as if your water inlet valve is not closing fast enough allowing a small amoutn of water to accummulate in fill tube freezing and eventually freezing solid, would try replacing water inlet valve, or even the water filter if this model is so equipped
Feb 18, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
