Question about Refrigerators
Not making ice
I may have touched something when I was cleaning it.Now the water is not making ice.What should I do?
How do I get it to make ice?
low gas charge
condenser fan fail
water pump not working
stuck in harvest mode
check the above
Dec 30, 2015 | Ivation Household Easy Touch Operation...
Have a scottsmanicemachine doesnt drop ice compressor on water on water runs on coils goes to harvest but makes no ice coil usualy have a ice buildup before it harves
The water runs over the evaporator coil(plate) until the ice gets thick enough, than when the ices touches a switch for the thickness you have it set for, it to go into harvest and the hot gas from the liquid line goes through the evaporator making the ice fall. If you are not making ice, it is the refrigeration system not working, so check the refrigerant, compressor etc like you would on any refrigerator or freezer
Dec 09, 2014 | Coffee Makers & Espresso Machines
Ice cube dispenser not working
Hi there, did you find the answer to this problem? We have exactly the same issue. We noticed a burnt smell in the freezer, mainly transferring to our hands when we touched packaging. The ice dispenser was working fine but the ice started to taste funny (a bit like burnt plastic) and had black bits in it. We took it out to clean the tray and since putting it back in, it just won't work. We don't know if we have put it back in wrong or if something has blown. We can still hear the motor when we try to press for ice, but nothing comes out. No water is making its way into the ice cube tray to form the ice, but we still have cold running water. I would be so grateful for any help. Thanks
Mar 16, 2014 | Ovens
B20cs50sns bosch ice maker stopped making ice
sounds like you have no water coming in...pull the line..make sure u got water..vacuum out the back fins and bottom so theres no dust or build up on the cooling fins..clean the inside..plug it in and try it..
Jan 08, 2014 | Bosch Refrigerators
I;m not getting any water to my ice maker for it to make ice?
It isn't the water supply hose that would be frozen since that is outside of the refrigeration area.You need to verify (if you haven't done so already) that you actually have water supply to the back of the fridge first. If so then take and clean the mesh filter on the fill valve.Use a needle, pin, or a sharp pointed pick to remove it.
Clean the filter (by using toothbrush or a small fine wire brush, and brush it under a slow running water tap). You can see how well you've cleaned it by holding it up to a light and you will see whether there are areas which may require more attention.
Once you are satisfied that it is clean, place it back in and connect your water and test.
Also an icemaker has something called a fill cup, which holds the water from the supply hose as it is being drained into the ice mold. If this ice maker part is not aligned properly, water doesn't make it from the supply valve to the ice mold, and you don't get any ice. Check to make sure your fill cup is properly aligned. You can check this ice maker part by removing the ice bin and having a look, adjusting if necessary. If you have ice forming on the water spout, you could have a leaky water inlet valve, another ice maker part which will need to be repaired.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting
Sep 30, 2010 | LG LFX25960ST Stainless Steel French Door...
Frigidaire FSC23F7DSB0 Dispensing Water Causes Ice Tray Overflow
Computer board?...doubt it. This sounds like two solenoids (an electro-magnet that when energized sucks into it a mechanism, water valve etc)...the 2 solenoids might be sharing the same connection.
The two solenoids are "separate devices" and usually behind the fridge at the bottom. One is for water on the door and the other the ice maker triggers...although they might look like one whole solenoid as sometimes the water feed runs through it to feed the other. They are still "electrically separate."Look for something that got bumped / wire terminals touched together.
Dec 05, 2017 | Frigidaire FSC23F7D Side by Side...
Icemaker quit working after I cleaned the coils.
After checking the fill tube (line that fills the icemaker) to make sure it's not frozen , pour about 3/4 cup of water into the icemaker . If the icemaker dumps the water but doesn't refill , replace the water inlet valve . If the icemaker doesn't dump the ice , replace the icemaker . ALSO , make sure the fan which cools the compressor is working . Possible when cleaning the coils , a glob of lint or something , was sucked into the fan and blocked the blade from turning .
Aug 04, 2009 | Whirlpool ED5FTGX Side by Side...
Machine is running but i have no ice
If runs water all time suspect water valve is stuck with scale or something holding it open. Waster will continue to flow and no ice made because introduces new water into sump all time.
Turn off water and see if makes ice. If so remove water valve and take apart and clean or replace as needed.
Dec 16, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Under counter sub zero ice machine. stoped making ice
Try this! Clean water tube, Check Ice sensor ( small wire (red tip) set to close to ice plate ) To close ,no build up sets off to soon.
Dec 11, 2008 | Sub-Zero 690 Side by Side Refrigerator
Hi , small fan motor inside the infeller was touch to the build up of ice., it need to manual defrost to lesser the ice inside .
Jan 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
