Question about Android Cell Phones
How do I sync my android phone to my Galileo Pro?
I received an 11.5 galileo Pro for Christmas and it already has 80% memory used. Do I do a hard reset? Or is there another way to get rid of the memory?
You don't want to 'get rid or memory', you need to regain memory.
The tablet only has 32GB of memory and some of that memory is used for the operating system. My iPhone has 128GB memory and despite having 4,000 images and 120 Apps, I have 80% free. You need to work out what you have that is using lots of memory space. Apps like Google Earth are huge. Videos and Films take up space. Yes you can do a Hard Reset, but it will delete everything you have on it and reload the operating system clean.
Not bad specs for an $80 tablet APART from the lack of memory!
RCA Galileo Pro 11 5 32GB 2 in 1 Tablet with Keyboard Case Android 6 0...
Jan 03, 2018 | The Computers & Internet
How do you Sync your Android SD Card with Google
<p>A phone with Android can synchronize accounts with Google Gmail, Google Calendar and Google Contacts. You can select what to sync Google Account if you do not want them all, all computers and sync Android phone. Manually synchronize your accounts when you make changes that are not reflected on your Android phone. <br /> <p><br /> <p>1. Tap the "Applications" below. <br /> <p><br /> <p>2. Scroll down until you app "My Account" and tap it. <br /> <p><br /> <p>3. Choose your Google Account and customize your synchronization options. Gmail, Calendar and Contacts synchronization are available and you can turn on and off at will. <br /> <p><br /> <p>4. Press the menu button Android. Tap the "Sync Now" synchronization between your phone and select the Google Account and power applications. <br />
on Aug 18, 2011 | Google Android
How to Sync SIM Card Contacts with Gmail of your Android phone
<p>You can use your SIM card contacts to your phone Android on your Gmail account, importing contacts in the phone memory. No additional software required. You can use the contacts on the phone and then sync them from the operating system Android. Depending on the operator, manufacturer and version of its Android operating system, the settings a little different, but most android phones use the same steps. <br /> <p><br /> <p>1. Open the screen of your Android phone and tap Contacts. <br /> <p><br /> <p>2. Press the "MENU" and press Settings. <br /> <p><br /> <p>3. Select "Import from SIM card" and press "OK". <br /> <p><br /> <p>4. Press the "Home" to return to the main screen and press "MENU". <br /> <p><br /> <p>5. Tap Settings and then Accounts. In some Android phones, is this option called "Accounts & Sync." <br /> <p><br /> <p>6. Tap your Gmail account and check the "Sync Contacts" is checked. <br /> <p><br /> <p>7. Press "MENU" and press "Sync Now". <br />
How do I reset RCA Galileo Pro
Two methods, but save data to computer before using:
Method 1:
Home screen-->Menu keys-->Settings-->Privacy-->Factory data reset-->Uncheck SD Erase-->touch Reset Phone-->touch Erase Everything
Method 2:
With tablet off, press and hold volume up-->With volume up held, press power button--> Release buttons when RCA appears-->When Android bot appears, press and hold both power button and volume up button-->When menu appears, use volume up and down to navigate to wipe data-->Press the power button-->Use volume up and down to navigate to Yes delete user data-->use power button to select that-->Press power button-->Upon reboot and seeing Welcome, choose your options-->Press Start when finished
Dec 26, 2017 | Galileo Optics
Is the RCA Galileo Pro 11.5" 32GB Tablet with Keyboard Case Android 6.0 BLACK Touchscreen expandable to 128??if so whar do I need
Yep - you just need to replace the micro SD card with higher capacity - a review that I read says it will take 128GB - you should check this out in the manual first in case this is wrong..
May 02, 2017 | Tablets & eReaders
How to Transfer Data Contacts from Huawei to Samsung Galaxy S8/S8+?
Phone to Phone Transfer is the all-in-one yet professional data transfer tool which can transfer photos, contacts, music, videos, calendars, call logs, messages, apps and app data for you. It supports iPhone, Android Phone, Blackberry, Nokia, Windows Phone perfectly. With it, you can copy data from one phone to another without any difficulty. So, you can easily sync all your data from the old Huawei phone to Samsung Galaxy S8/S8+ by using this tool.
How to Transfer HTC LG Sony Huawei Data Contacts to Samsung S8 Edge
Apr 28, 2017 | Samsung Cell Phones
I need a free manual for my new RCA tablet model#RCT65138W87DKC
RCT65138W87DKC is the RCA Galileo Pro 11.5" tablet. RCA has the manual for this tablet on the product page: . Scroll down to the Download the Manual button. The direct link to the manual is currently .
I hope this helps.
(I believe the final C indicates the case color.)
Mar 15, 2017 | Tablets & eReaders
Register RCA Galileo tablet
not sure if this is how you do it but if you scroll all the way to the bottom of the screen on the left hand side you will see where you do register a tablet.. RCA RCA Android Tablets
Dec 09, 2016 | Galileo Optics
How to synce from my android phone to my apple phone
Tap Move Data from Android While setting up your new iOS device, look for the Apps & Data screen. Then tap Move Data from Android. If you've already finished setup, you'll have to erase your iOS device and start over. If you don't want to erase, just transfer your content manually.
Mar 06, 2016 | Apple Cell Phones
My phone can't receive gmail says not synced also on my computer it keeps coming up gmail not synced
About 889,000 results (0.83 seconds) Search Results
    Gmail won't sync (Android) - Gmail Help > ... > Android 4.0+ > Open & read email
    GoogleCan't send mail, or mail is stuck in send; Can't receive new mail; Can't open or ... Inbox not loading; "Account not synced" error; Not receiving notifications for ...
    Gmail app is not syncing automatically on my phone - Google ...
    GoogleApr 4, 2015 - Gmail has stopped syncing automatically on my phone. ... reinstalled, ticked boxes, and it works once then doesn't do it again. i can't find what the issue is. ... I still cannot receive any email after updating to the latest version so i guess i need to just wait .... My accounts section says sync disabled for google. Gmail not Syncing all of a sudden
    May 8, 2015
    Can't sync google accounts on Android phone after ...
    Jan 17, 2014
    GMail App Not Pushing (GS4)
    100+ posts
    Jan 1, 2014
    Gmail will not sync on my Android phone
    Nov 19, 2009
    More results from
Jan 25, 2016 | Cell Phones
Cell Phones Logo
29 people viewed this question
Top Android Cell Phones Experts
Owen Barnes
Level 1 Expert
Shawn O'Brion
Level 1 Expert
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
