Question about Garden
Drive chain comes off - Garden
  • Garden Master
  • 20,463 Answers
You have to adjust the bar to keep tension. Google
make model manual
Google
Posted on Dec 28, 2016
I need to replace the chain on the drive.
closely look along the sides of the chain and look for a lock key between to links
push the key sideways and then dissemble the link and the chain will come off
Same as a push bike chain link
Feb 19, 2016 | Garden
How do i fix a slipping chain drive
U cud hav a worn chain. U need to torque down the bolts that loosen it. Dont put tumuch strain on chain..it mite break and cause an injury
Sep 18, 2015 | Garden
Weed eater one drive chain comes off
The problem with the chain Is the tensioner. There is not much the small spring can do. You may try to add tension to the chain but, not a good design.
Jul 20, 2014 | Husqvarna WE261 960220007 26 190CC Weed...
Roper snowblower drive chain keeps coming off
sounds like you have either stretched chains or worn sprockets. Also check the outer bearing that the shafts fit into for wear. If they wear then the chain can't retain it's tension properly, get sloppy and then derail itself. Most likely your bearings is the problem.
Dec 02, 2013 | Craftsman 16" High Garden Tractor Snow and...
Chain keeps coming off bar
The chain only comes off the bar if, the chain has become lose and de railed, or if the timber you are cutting is very springy and you are trapping it in the cut, our twisting it in the cut, if the saw is not oiling the chain correctly it will stretch and if not addressed will come off, once it has come off the drive links are usually damaged, you should realy start again with a new chain, when running close to a clean peice of wood you should a steady stream of chain oil coming from the end of the guide bar.
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
The engine starts but the chain does not move even when the throttle is applied and then it starts to smoke the whine does not sound like it has full power either
Can you move the chain by hand? If not, the chain brake may be set or damaged so that the chain cannot move. Is the chain adjusted extremely tight? Is bar oil getting to the chain? The smoke is probably coming from the clutch which is trying to drive the chain. The chain should be adjusted so that the chain just comes up to the lower bar edge, but allows free turning of the chain by hand. Get back to us if you need further help.
Nov 03, 2010 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
I have a whirlpool electric dryer. There is a chain coming out around the inside of the back area of the dryer. It has come out about 12 inches. What is that part and is it fixable?
ive never heard of a chain drive dryer cept commercial dryers use a chain drive your chain is most likely a safety chain that was once hooked to the wall its perpose was if a child opened the door and leaned or sat on the door the dryer would not tip over they use safety chains on ranges for the same reason hope this helps
Sep 24, 2010 | Whirlpool LER4634J Electric Dryer
I HAVE A POULAN PRO 260 42cc 18 inch THAT IS 5 yrs old REPLACED BAR AN CHAIN . WENT TO CUT SOME TREE LIMBS CAN NOT EVEN MAKE ONE FULL CUT AN CHAIN COMES OFF AFTER 4 TIMES WENT AN RENTED ONE.
Remove the new chain and compare it against the old one. Do the new drive teeth match the 'pitch' of the old chain? If incorrect, the chain cannot be adjusted properly and will 'climb' over the sprocket due to the chain teeth not matching the teeth on the drive sprocket. Getting the proper chain is the answer in this case. Hope this helps!
May 02, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
Chain comes off mcculloch electramac em250 chain saw
Adjust the chain until you can pull on it and it will come away from the bar but will not hang from the bar. If that does not solve your problem then the chain or drive gear is worn out. If the oiler is not working it is for sure worn out.
Apr 25, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
My electric chainsaw used to carve ice, chain stops while motor still spins when cutting ice
Is there some form of tensioner for the chain or do you believe it's the drive sprocket?Gas chainsaws have a bolt you can tighten which takes up the play in the chain.The drive sprocket is either on a key-way or clutch.I would remove the chain and check the drive sprocket.There must be a clutch to allow the motor to free spin until a given RPM would drive the chain.That clutch is suspect.You didn't give any information(make or model of chainsaw)that I could use to search for an answer for you.Try to work on that clutch,re-post if you need more help.
Jan 13, 2010 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
