Question about Samsung Televison & Video
SAMSUNG TV REPAIR of modle= CZ-21E6V
TDA 9381 IC is ok and vedio op ic TDA6107 IC is also ok but picture is dim.Voltages at 51,52,53 are bellow 0.9volts (TDA 9381).
5 Suggested Answers
  • 556 Answers
SOURCE: missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Posted on Sep 23, 2007
  • 579 Answers
SOURCE: TDA 8364
Look it up at nteinc.net
Posted on Jan 02, 2008
  • 56 Answers
SOURCE: my samsung TV can't display
check feedback path from collector of h output tr, check voltages at pin 5 of tda 6107 it shuld vary wrt screen voltage
Posted on Jul 19, 2009
gopakumarg43
  • 74383 Answers
SOURCE: Samsung crt tv ic tda 9381 mute system not working &No audio . audio ic tda 7297sa
IC fault. Replace the TDA9381. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Posted on May 29, 2016
May 29, 2016 | Samsung Televison & Video
Tda 9370
Check the video output RGB out terminals of the TDA9370. Check the voltages. If can, check signal waveform. You have't specified nothing about the audio status. If you wish to get the schematic of TVs, using TDA9370, check the site linked here. Never confirm that the IC is OK. Check the serial data & serial clock. Replace the main system control memory IC, too. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 21, 2013 | Televison & Video
Lg synch fault
I do not no what you mean by using 9381 ic? In the audio or setup menu there is a adj for audio delay . Without knowing the model code that is the best I can do?
May 31, 2013 | LG Televison & Video
Jvc tv av25vt14 have sounds but no picture black osd
check first the rgb drive voltages coming from uoc it measures 2.2vdc not 0.542vdc.If your multimeter reads 0.542 your crt screen looks like a dim picture with a retrace line on it. Replace ic 351 which is tda6107, cured the problem.
Aug 15, 2011 | JVC Televison & Video
Description of all pins in ic TDA11105PS/N3/3/AE1
5 supply Volt missing in IC TDA 11105ps/N3 used in beston tv
May 13, 2011 | Televison & Video
Hi samsung tv using TDA 9381ps/0489 problem is Retrace line sound ok
180 volts from LOT o/p to drive pict-tube guns is missing . or vedio driver ic is faulty.
Jan 22, 2010 | Samsung Televison & Video
Missing vertical deflection on philips TV
Sep 22, 2007 | RCA 13R400TD 13" TV
Televison & Video Logo
174 people viewed this question
Henry  Thomas
Henry Thomas
