Question about Microwave Ovens
Do microwaves have a belt drive to turn them ?
    Top Expert:
  • Microwave Ovens Master
  • 47,776 Answers
Depending on the make and model but many do underneath the bottom cover of the oven
Posted on Dec 28, 2016
Jerky turntable heating o.k. just very jerky, does it have a belt or direct drive? can i get a replacement motor?
Mick,
Most are a direct drive motor. You can usually turn your microwave on it's back and be able to access the drive motor through a panel on the bottom. It does have an electrical connection, so remember to unplug your microwave before working on it. Most microwave repair parts places should carry a new motor that will fit your unit. Hope this helps!
Sep 12, 2015 | Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Samsung timesaver 1000w microwave turntable has stopped turning
Possible that the belt has failed, the motor has failed or the fault is the drive in the board. You need to start by checking the belt and motor.
click this link: Motor replacement
Apr 10, 2013 | Microwave Ovens
Turntable is very sluggish, intermittent (stops and goes) and often does not turn at all. Is there a user replaceable belt that drives the turntable?
The turntable motor or belt are replaceable, but finding the parts for some models can be challenging...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 16, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Microwave Drum not moving Problem
Remove the plug and take the turn table out of the microwave cabin. Now keep the microwave rested on the side andopen the back pannel,you can see the turn table belt drive.If this is broken replace.if not trace the motor connection and mark them.Now heat the microwave in normal position,place the turn table and a cup of water.Close the door and switch on the microwave set for a minute.Now check the voltage on the motor line marked.If present ,then the motor is fault.If not the controller board is faulty, and must be traced.Can be the relay drive or the relay. hope the other sections are working fine.
Aug 31, 2010 | Microwave Ovens
The turntable makes noise and is jerky as it turns
I believe your turntable is belt driven as opposed to direct drive. Your little belt is nearing the end of its useful life, I think.
Remove the cabinet. Turn the oven on its back. Look at the bottom.
Oct 20, 2009 | GE JVM1850 1000 Watts Microwave Oven
My Maytag microwave makes a loud sound and it stopped rotating (I have turned the rotator on several times).
this is due to the magnitron tube is arching and there is possibly grease or dirt around it .You may need to replace the microwave. The drive for this model may be belt driven and the belt is worn and slipping. Repairs for this is usually a lot more than a new microwave.
Aug 05, 2009 | Maytag Microwave Ovens
GE micro wave Spacemaker
The turntable is either plastic gear driven or uses a belt. either way, it's usually all non metallic due to the microwaves. you'll need to see if the motor that drives these are turning by removing the case. this can be EXTREMELY dangerous as the radiation from the cylstron tube. if it's a simple as a belt, the part can be replaced. good place to go is www.repairclinic.com
Be sure and rate me for this solution
Feb 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turntable won't turn
You will have to take it out and then take off the outer cover to expose the drive system for the turntable unless the items turns with the turntable removed. If it does then (and if it is belt driven) the belt may be worn and slipping. Anyway you look at it the cover has to come off to see what is happening.
Feb 08, 2008 | Jenn-Air JMC7000 Microwave Oven
Turntable won't turn
Hi , unscrew the cover check belt are tear / if tear replace belt , lose the belt tensioner if it has , if not just install incline belt into vevil of pulley.
Jan 15, 2008 | Kenmore 63252 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
