Cell Phones Logo
l
larry taylor Posted on Dec 28, 2016
Tap size for bacd2085n030m - Cell Phones
1 Related Answer
Bill Boyd
  • 53816 Answers
  • Posted on Dec 28, 2016
SOURCE: boeing spec tap size for bacd2085n030m
you will need to explain what is a bacd2085n030n as that means nothing to anyone but you
is it a screw , a plug a electronic unit or what
post it all again as posts are not linked if you want an answer
So I strip my headbolt out, and I was thinking about tapping dying, I need to know what tap I should use what size it,
When you go to buy the helicoil insert, there will be one for the size that you stripped out, just take a plug with you to make sure you get the right size by comparing. The insert tells you what size tap to use, some come in a kit with the tap and helicoil.
I'm trying to find out what size bolts are needed to fasten down the reservoir
Look at the bolt holes, are they tapped/have threads? If so, you could get a tap and die set, find the proper size tap to chase the threads. You might be able to use slightly larger tap and rethread the hole. The tap usually has the size and thread stamped on it. If that is a self tapping screw that holds it, You could get a self tapping screw slightly bigger than the hole and screw it in.
Of course I can see anything from here. Your talking about coolant reservoir?
Boeing spec tap size for bacd2085n030m
1helpful
Font size automatically increased. How do I decrease it. Nothing is working
Hi Kate, If the words are too big then tap on "settings", Then up the top you tap on "my device" OR "device" then tap on "display" then scroll down and tap on "front size" then tap on the size you prefer...I hope this helped... CHEERS
Apr 24, 2016 • Cell Phones
1helpful
How do i enlarge text? Im visually impaired and font is too small for me to read text messages or when sending text
Hi Maureen,
Depends on what phone you have...
FOR apple:
Here's how to enlarge text size throughout iOS on iPhone and iPad:
  1. Launch the Settings app from the Home screen of your iPhone or iPad.
  2. Tap on General.
  3. Scroll down and now tap on Accessibility.
  4. Now tap on the Large Text option.
  5. Here you have several options to make text larger throughout iOS. Tap on the one you'd like.
On Android:
  • Tap the app drawer icon from the home screen.
  • From the displayed list, tap the Settings icon.
  • From the Settings window, in the left pane, tap the Display option.
  • From the right pane, under the Font section, tap the Font size option.
  • On the opened Font size window, tap to select the appropriate radio button to set the desired font size.
Mar 11, 2016 • Cell Phones
2answers
What is the proper size drill bit to use for a 3/8 tap?
Thread size makes a difference:
3/8 x 16 NC is 5/16 drill
3/8 x 24 NF is Q size bit
May 24, 2015 • Drills
How to change view size in windows 8
You can change the view size in Windows 8 in the following ways:
1) By changing the size of text and other items on the desktop
You can change the size of text and other items (like icons) on your desktop without disturbing your current screen resolution settings. To do this, follow the steps mentioned ahead:a)Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), enter "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Drag the slider until the items in the preview image are the size you want them to be.
c) Tap or click "Apply".
You'll see the change the next time you sign in to Windows.
Also, you can change the text size for specific items (such as Window title bars or tooltips) without affecting the size of anything else on your desktop. Follow these steps to do this:
a) Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), entering "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Under "Change only the text size", choose the item you'd like to change and pick a text size. If you want the text to be bold, select the "Bold" check box.
Note: To view a pictorial description of the above process, refer to the link:
http://nvidia.custhelp.com/app/answers/detail/a_id/3153/~/adjusting-windows-8-display-size%2Fscaling-for-high-dpi%2Fppi-monitors
2) By changing screen resolution
You can change the view size on your desktop by changing screen resolution settings. To do this, follow these steps:
a) Swipe in from the right edge of the screen, tap "Settings", and then tap "Change PC settings" (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click "Settings", and then click "Change PC settings").
b) Tap or click "PC and devices", then tap or click "Display".
c)Tap or click the resolution slider and drag it until you find your desired resolution.
d) Tap or click "Apply".
To know more about the best screen resolution settings for your desktop, refer to "Set your monitor to its native resolution" section on the following link:
http://windows.microsoft.com/en-IN/windows-8/get-best-display-monitor
GuruAid.com
How can I change "font"?
Increase Font Size
(1) When you are reading, tap the Menu icon to display e-book settings.
(2) Tap "Font Size"to adjust the font size.
(3) Tap a size that you want, and then tap "OK"to confirm
Tap size
it is a special tap just for spark plug holes, any auto parts store will have one, it is double sided to fit both 5/8" and 13/16" plug size. very cheap to buy.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
