Question about Chef's Choice Kitchen Appliances - Others
How can I open the top of a CHef's choice WafflePro 840B ? A little bolt inside dropped and now my waffle maker does not close as well as before.
Krazytech
  • 725 Answers
SOURCE: water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Posted on Aug 25, 2007
  • 758 Answers
SOURCE: vitantonio waffle maker
It sounds as if the iron isn't cooking at a high enough temperature. I'd try turning the iron to the highest setting, first (the thermostat may not be giving a correct reading, keeping the temp too low), before considering getting a new iron. The good news, though, is that a new waffle will only set you back about $20
Hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on May 05, 2008
SOURCE: removing top of waffle maker to clean it
The other night my wife had the same issue. My thought had always been to wipe it down using a wet cloth with simply hot water and rely on the extreme heat of using it to sterilize it.  My wife decided instead to disassemble it.  The problem is that it is not made to disassemble and she bent some parts and broke others and stripped out screw heads.  It is clean now, but can not be reassembled without extracting stripped screws and replacing some parts. My advice to you is - don't try to disassemble it. The factory went to great lengths to ensure that you don't.  Instead use a soft cloth dampened (not dripping wet) with the hottest water you can.
Posted on Dec 29, 2008
cactus bob
  • 267 Answers
SOURCE: older waffle maker is not heating up
thats a high temp fuse you can jump it out to test the rest of the waffle maker but dont leave it jumped out , its not safe that way . that fuse is hard to find try google "fuse high temp 185 c " please rate this answer , i need it to "get my wings" thanks
Posted on Jan 16, 2009
  • 5 Answers
SOURCE: Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Posted on Mar 09, 2009
Tip
Permanently fix the waffle maker when it breaks in the back swivel which makes...
Carefully drill a tiny hole in the center of the back plastic part.  Then drill a 1/4 inch hold centered on the first drill hole.  Put a 1/4/ threaded rod through the hole with a locking bolt on each side. But extra threaded bolt with a hacksaw.  Tighten bolts to just touch plastic.  See picture attached for solution.  When drilling hold be careful not to tough the plastic coated wire bundle.
on Mar 12, 2014 | Waring WMK300 Professional Belgian Waffle...
How long do i keep the waffle batter in
Shortly after closing the waffle iron it will start to steam, Watch when the steam stops and open the iron. The waffle should be golden brown.
After you get the hang if it you can adjust the cooking time for lighter or darker waffles. There are videos on Youtube that may help too.
Jul 03, 2014 | Black & Decker WMB505 Waffle Maker
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
Won't turn on unless wiggle cord
Had the same problem and cord wiggling worked for a while then no lights anyway I tried. I opened up the handle, and the 3 screws below the handle, to disassemble that part and looked into the little circuit board. The little on/off switch worked directly from the cb so just re-seated everything and Wiola! it works now. Seems like the little silver on/off button at the top loses contact with the actual switch inside and in my case re-seating restored that contact.
Hope this helps..
Feb 11, 2010 | DeLonghi WR25 Retro Belgian Waffle Maker
I am looking for a replacement rubber foot for our waffle maker. It's the sunbeam 3 in one sandwich grill and waffle maker. It's the little black rubber foot that keeps it from wobbling. Any ideas...
Go to:
http://www.sunbeam.com/ServiceLocator.aspx?section=kitchen
Then select your area from the drop down menu to find out where your nearest service center is.
Best wishes,
Graemevm
Jan 10, 2010 | Sunbeam 3852 Waffle Maker
I don't have the manual. How do you clean after use?
I have the same waffle maker and I just basically take a damp wash cloth and wipe it out. It's non stick coating makes it easy to clean this way. Another way is I run it under the sink faucet with the cord hanging down the cupboard so it doesn't get wet and this works good also. Hope this helps.
Aug 09, 2009 | Chef's Choice 830 / 830B Chrome WafflePro...
Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Mar 16, 2008 | Nordic Ware 15040 Belgian Waffle Maker
Kitchen Appliances - Others Logo
Top Chef's Choice Kitchen Appliances - Others Experts
Rommel Balcita
Tom Chichester
Jerry Martin
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
